Bigger Lift?
tarheel4x4
PostPosted: Wed Jan 11, 2006 2:02 pm    Post subject: Bigger Lift? Reply with quote
I currently have a 3 inch lift on my 2000 xj. I want to go up to a 4 in or 4.5 but no more. My leaf springs are saggin and i want to change that. What are some good ideas on how to get the additional lift i want.
PostPosted: Wed Jan 11, 2006 7:20 pm    Post subject: Reply with quote
did you do aal or all new packs?
s10 leaves work in the rear ive seen where people have posting doing that to their rigs on here
coil spacers would work for the front...
tarheel4x4
PostPosted: Wed Jan 11, 2006 7:48 pm    Post subject: Reply with quote
i have aal.
PostPosted: Wed Jan 11, 2006 8:57 pm    Post subject: Reply with quote
PM some of the guys running the s10 leaves...see how much they got from them and use the coil spacers for the front
Renegadestang
PostPosted: Thu Jan 12, 2006 9:34 am    Post subject: Reply with quote
If your springs were sagging before, aal won't add lift for very long. The best thing to do is buy new spring packs.
Nokatay
PostPosted: Sat Jan 21, 2006 10:47 am    Post subject: Reply with quote
Hi, I'm new here but have had stock Jeeps for some time. We will be considering a lift for a '90 XJ. Can the coil spacers be used without having to change brake lines or steering components? Or more directly, how much lift can you add before you have to start changing lines and components?
tarheel4x4
PostPosted: Sun Jan 22, 2006 7:17 pm    Post subject: Reply with quote
anything exceeding 3 inches of lift is when u'd need to start changing the brake lines and etc.
Nokatay
PostPosted: Tue Jan 24, 2006 10:30 am    Post subject: Reply with quote
Thanks
1990 XJ
2003 Liberty
PostPosted: Thu Jan 26, 2006 1:12 pm    Post subject: Reply with quote
I had that problem with Skyjacker 3" w/ AALs. I removed the AALs and installed Superlift 3" rear leaf springs. Makes all the difference in the world. They are firmer and flex great.
