Code 24?
The Dajaaza
PostPosted: Sun Jan 29, 2006 1:54 pm    Post subject: Code 24? Reply with quote
The rig (97TJ) began idling high today at about 1700rpm's but ran fine. About 200 kilometers later, the idling came back to normal but the engine light came on reading code 24 and the vehicle began to buck and has been progressively losing power.
Code 24 reads: Throttle position sensor input above or below acceptable voltage. TPS signal does not correlate to MAP sensor.
Does this mean that the throttle sensor is gone or could it possibly mean that the MAP sensor is gone? Anyone out there with insight?
J
KnightFire
PostPosted: Sun Jan 29, 2006 2:21 pm    Post subject: Reply with quote
Try replacing the TPS first. That should do the trick.
2002 TJ Wrangler X
Patriot Blue 4.0L
Check Website for Mods/Photos
Amsoil Dealer
The Dajaaza
PostPosted: Sun Jan 29, 2006 2:31 pm    Post subject: Reply with quote
Expensive?
Keithd2606
PostPosted: Sun Jan 29, 2006 6:17 pm    Post subject: Reply with quote
i replaced mine think it was 40 - 50 bucks
It might not be very long...but it'll bust the sides outa a tuna can!
