Rubber Flap or belly tarp
jeep_cherokee_girl
PostPosted: Mon Feb 06, 2006 12:58 pm    Post subject: Rubber Flap or belly tarp Reply with quote
Ok I found the post about the rubber flap that goes from the radiator to the front axel. Where can I get one or what are they called? Also saw something about a belly tarp? Where can I get those? My snow is blowing in and getting wires wet and vehicle stalls. Plus I'm sure it will help the heater.
PostPosted: Mon Feb 06, 2006 2:49 pm    Post subject: Reply with quote
The FSM calls it a "splash guard". Mine was falling out when I ripped it out about 2 years ago. It's most likely a dealer only item.
Haleyes
PostPosted: Mon Feb 06, 2006 8:53 pm    Post subject: Reply with quote
If the vehicle stalls cause wires are getting wet, shouldn't you fix the wires? Keeping the wires from getting wet by installing a splash guard is just masking the actual problem.
96' XJ Police Special @ 3in. on 30's
www.naxja.org
jeep_cherokee_girl
PostPosted: Tue Feb 07, 2006 8:44 am    Post subject: Found the Problem Reply with quote
When we got there my friend was checking it over again and found that the ignition coil was cracked. So he replaced it today and no problems comming home.
