error code help
aixelsyd
PostPosted: Wed Feb 08, 2006 12:38 pm    Post subject: error code help Reply with quote
Hi!
I have a 92 YJ 4.0L 5spd and yesterday all of a sudden the check engine light came on. When I ran the codes I got a 12, 33, 24, 41 and the end code 55. I can't seem to determine what the 12 means (not on any list I can find) and for the 33 (Air conditioning clutch relay), I don't have AC so that boggles me as well. The other 2 code I understand and am tracking them down (TPS sensor and alternator field). Can anyone provide some assistance? Thanks, Greg
PostPosted: Wed Feb 08, 2006 12:47 pm    Post subject: Reply with quote
I believe 12 is a recently disconnected battery.
http://jeephorizons.com/phpbb/viewtopic.php?t=2719
jppilot61
PostPosted: Wed Feb 08, 2006 12:50 pm    Post subject: Reply with quote
12 = Battery Disconnected
33 = A/C Clutch Relay Circuit
24 = Improper TP (Throttle Position) Sensor Voltage
41 = Alternator Field Switching Improperly
55 = Completion of Fault Code Display
1992 XJ Laredo
RE6130 4.5" XJ Super-Flex Kit
aixelsyd
PostPosted: Sat Feb 11, 2006 7:36 pm    Post subject: Problem resolved Reply with quote
Turns out it was the TPS sensor. Once I replaced that all is well again. Thanks for the help! Greg
