Front End Pulling to Right and Left
RussellRowell
PostPosted: Thu Feb 09, 2006 10:29 am    Post subject: Front End Pulling to Right and Left Reply with quote
I had a accident a few years ago and ever since, my jeep doesn't steer straight. Jeep has new tires (LTX AT) and front end alignment. Still same problem. I was told my control arm bushings were bad so I replaced with Poly bushing kit. Helped a little Neutral Jeep mostly pulls to the right but when I get on a road that slants towards the median, Jeep pulls to the left. So I know the alignment is good. What else could it be? Could my steering box be bad? I wanna say it leaks fluid. Any suggestions please!
Stevo02TJ
PostPosted: Thu Feb 09, 2006 11:00 am    Post subject: Reply with quote
When you park for extended periods of time, do you notice leaks on the ground?
PostPosted: Thu Feb 09, 2006 11:04 am    Post subject: Reply with quote
look at your pitman arm is it saturated?
RussellRowell
PostPosted: Thu Feb 09, 2006 11:09 am    Post subject: Reply with quote
Yes and Yes
PostPosted: Thu Feb 09, 2006 11:23 am    Post subject: Reply with quote
then you have a leak you mite get lucky and by adding an aftermarket stabilizer and it will fix it
dont know how that fixed my leak but it did and before anyone else says does it have fluid yes it does
RussellRowell
PostPosted: Sat Mar 11, 2006 12:35 pm    Post subject: Reply with quote
Well, after giving it much thought. I decided to change out the steering gear. I bought a used one for 75$ and 5 hours later my issue was solved. Now the steering is tight and doesn't pull to the left or right. Next, replacing all ball studs.
1994 w327k
