HELP! Jeep won't start
bomax
PostPosted: Sat Feb 11, 2006 2:47 pm    Post subject: HELP! Jeep won't start Reply with quote
I have a 96 and when I turn the key it will crank, but won't start. I checked fuel pressure and it reports zero. Confused
The fuel pump relay works as expected. I can't find the fuse though so I checked the voltage under the car near the fuel pump and when the key is turned the black/blue wires get 5V. I assume that is the power to the fuel pump?
I don't hear the fuel pump prime when the key is turned... uggghhhh...
So, unless anyone has any other suggestions or further tests, I am going to diagnose it as a failed fuel pump and replace it. I plan to cut the hole as outlined in the thread at the top of this forum. 18" from the latch and 18" from the drivers side??
bomax
PostPosted: Sun Feb 12, 2006 2:11 pm    Post subject: Reply with quote
Ok so, after pulling the fuel pump and testing, I think it's ok. I rechecked the connector on the car and confirmed it is not getting 12V. (Orange and Black).
Is there a fuel pump fuse somewhere that I'm missing??? Please help!
