94 Cherokee electric running non stop
magnum4x4
PostPosted: Wed Mar 08, 2006 4:17 pm    Post subject: 94 Cherokee electric running non stop Reply with quote
The other day I replaced the thermostat in my 94 cherokee sport. It has the 4.0L with manual 5sp. I put the 180 degree in when it called for the 195 degree thermostat. Today after a long, stop and go ride home the elec. fan ran non stop after turning off the motor. It ran for 5 min. maybe more before I unplugged it. Could it be because I put the wrong thermostat in or a bad sensor. If you think its a sensor where is it located? Thanks for your help in advance!
majikxms
PostPosted: Wed Mar 08, 2006 5:42 pm    Post subject: Reply with quote
Could possibly be a bad relay switch. It should be in the fuse panel under the hood. This happened to my 98 XJ, my wife thought it sounded different, but did not hesitate to go into work and let the battery drain. rofl
I checked the relay by temporarily replacing it with another in the fuse panel...the fan shut off. I changed the relay and it worked as designed.
