what kind of jeep axles in a 71 jeep pickup?
jeepman355
PostPosted: Mon Mar 13, 2006 8:46 pm    Post subject: what kind of jeep axles in a 71 jeep pickup? Reply with quote
i just bought the axles out of a 71 jeep pickup does any one know what size they are?
84' CJ7, CHEVY 355 11:1, TH350, NP205, DANA 44'S, 6" RUBICON EXPRESS LIFT, SWAY BAR DISCONNECTS INFRONT, 33" SUPER SWAMPERS. OH YEH 450 HORSE POWER!
PostPosted: Mon Mar 13, 2006 9:10 pm    Post subject: Reply with quote
The dimensions or model?
Rear axle:
Dana 44 (Wagoneer and 1/2 ton truck: 1971-1975, wide tracks: 1974-1983, Grand wagoneer: 1987-1991)
AMC 20 (Wagoneer and 1/2 ton truck: 1976-1986)
Dana 60 (3/4 ton and 1 ton trucks: 1971-1987)
Front axle:
Dana 44 (1971 - 1991)
jeepman355
PostPosted: Tue Mar 14, 2006 6:32 am    Post subject: Reply with quote
IT HAS A 5 LUG BOLT PATTERN WITH A 360 IN IT THATS AS FAR AS I KNOW. THERE WEREN'T ANY MARKINGS ON THE TRUCK TO TELL ME RIGHT AWAY.
PostPosted: Tue Mar 14, 2006 12:57 pm    Post subject: Reply with quote
Well, during that year, both the Dana 44 and 60 used 5 on 5.5" bolt pattern. Have you pulled the axle shafts? The Dana 60 should have 35 spline axles and a 9.75" ring gear. The 44 should have 30 spline axles and a 8.75" ring gear.
jeepman355
PostPosted: Tue Mar 14, 2006 3:21 pm    Post subject: Reply with quote
I JUST GOT THE AXLES OUT OF THE TRUCK AND THE FRONT IS CLOSE KNUCLE DRUMS WHAT SHOULD I DO?
shotgun
PostPosted: Tue Mar 14, 2006 3:35 pm    Post subject: Reply with quote
Swap it from what I've seen
jeepman355
PostPosted: Tue Mar 14, 2006 5:18 pm    Post subject: Reply with quote
WHAT ARE SOME LOW COST DRUM TO DISCS SWAPS THAT ARE OUT THERE. DO THEY A SWAP FOR A CLOSE KNUCLE FRONT DANA 44?
PostPosted: Tue Mar 14, 2006 8:47 pm    Post subject: Reply with quote
I searched a while back, but nothing cheap and easy jumped out.
http://jeephorizons.com/phpbb/viewtopic.php?t=6338
jeepman355
PostPosted: Wed Mar 15, 2006 8:14 am    Post subject: Reply with quote
code3tj, do you want to sell the parts to do the conversion to disc or give me a parts list of stuff i need to get at the junk yardto do the conversion to disc.
PostPosted: Wed Mar 15, 2006 11:11 am    Post subject: Reply with quote
Sorry, I don't have anything to sell, but here's the info I found (from the link I posted):
One of the reasons you see so much information for Scouts and Bronco's is because they have the same problem you and I do. Drum brakes and a 5 x 5.5 wheel bolt pattern. This same bolt pattern was used on 2 and 4 wheel drive Ford 1/2 ton/Bronco from about '73 to '95. Those are the years you need parts from.
Ford spindles from those years used the same wheel bearings as Chevy until about mid-year '74 and Jeep until about '76. After that Chevy and Jeep went to a larger bearing and spindle. If you can get an axle from an early Chevy/Jeep with the smaller bearing/spindle then you can just slide the Ford hub/rotor over the spindle and you're there. Or you can find an early spindle to put on a later Chevy/Jeep axle. You can't easily swap on a Ford spindle cause it uses 5 bolts rather than 6. Once you get that done you pull the check valve out of the front side of the master cylinder and you should be home free.
If you're not set on using that axle, it'd probably be easier to get a new/different axle that doesn't have the closed knuckles.
jeepman355
PostPosted: Wed Mar 15, 2006 11:42 am    Post subject: Reply with quote
i think that i will try to exchange the axles. what is the best axles " in your opinon" that i should get with the least amount of modification. right now i have the stock amc 20 and dana30 in my 84 cj7. i want something a stronger and at least 4.10 gears.
