Rear Wiper Won't work - I've tried many things
Brad S
PostPosted: Sat Mar 18, 2006 11:34 am    Post subject: Rear Wiper Won't work - I've tried many things Reply with quote
My rear wiper (95 ZJ) stopped working about a month ago, it made a few last attempts, then stuttered to a hault. At first I thought it was the motor. I got a new motor and tried it, but it would not work. The autoparts store gave me a refund and returned my old motor to me. I took the old motor and hooked a small pair of jumper cables to the battery and straight to the two points of the wiper motor. This caused the motor to start moving, but slowly with a squealing noise.
I then went to this page: http://www.nagca.com/grandtech/rearwiperrepair.htm and followed the instructions to clean out the corrosion and buildup in the wiper shaft. This fixed the problem of the motor strain. When I hooked it up to the battery again, it worked great.
OK, so motor is still good.
I then hook it back up to the pigtail on the liftgate, but it still doesn't work.
I check the fuse for the rear wiper in the fuse box, but it is still good.
I then proceed to electrical diagnosis, and this is where I am not sure about what I am doing totally.
I grab my electrical tester and proceed to check the pigtail to see if I'm getting power at the liftgate.
Here is the diagram of my plug:
I assume black is the ground, so I poke it with the neg. on my tester (set to read 20vdc). I then proceed to check each point.
1st attempt (wiper set to the 'on' position) - I receive:
Brown/Green - 0
Red/Black - 12.18
Brown/Orange - 0
Black/White - 0
Brown/Black - 11.48
2nd attempt (wiper set to the 'delay' position):
Brown/Green - 0
Red/Black - 12.18
Brown/Orange - 12.04
Black/White - 0
Brown/Black - 11.48
I am at a loss as to what to do next because I don't have an electrical diagram to tell me what the different colors mean. If someone could help me out, I would greatly appreciate it.
fireguy08
PostPosted: Sat Mar 18, 2006 5:27 pm    Post subject: rear wiper Reply with quote
It most likely is the ground wire, check at the connector that goes from hatch to body
PostPosted: Sat Mar 18, 2006 6:04 pm    Post subject: Reply with quote
Mine did this as well, i first checked the fuse and it was good but i noticed some build up on the prongs scraped it off to reveal shiny metal and it worked
Brad S
PostPosted: Sat Mar 18, 2006 6:22 pm    Post subject: Reply with quote
Hmm, ok, I'll check that again, thanks for the advice. When I checked it the first time, I seem to recall that it was shiny, but I didn't really look too closely.
daggie
PostPosted: Sun Mar 26, 2006 7:36 am    Post subject: Reply with quote
did you get it fixed ?
Mine did the same as yours, ie: worked on the bench but not on the jeep Rolling Eyes with the tail gate OPEN, I closed & it worked
95 XJ 3.5" lift, blah, blah, blah.
97 ZJ laredo 2.5 turbo diesel.......mmmm
Brad S
PostPosted: Sun Mar 26, 2006 1:52 pm    Post subject: Reply with quote
Nope, I have not gotten it fixed yet. I found out that I'm not getting power to the tailgate, using my volt meter, but other than that I don't know why. Fuse seems to be good. I guess it might be the switch??
oh and btw, yes the tailgate was closed. It still doesn't work.
I have a free oil change at the dealer, I think they might take a look at it. I told em to let me know what they find.
Jeep Iceland
PostPosted: Sun Mar 26, 2006 3:05 pm    Post subject: Reply with quote
I think there is a relay for the wiper motor too not just the fuse,check the relay.
F.D
1996 Limited 5.2
1976 Trans Am
Brad S
PostPosted: Tue Mar 28, 2006 1:23 pm    Post subject: Reply with quote
Is the relay attached to the motor, or is it in a different location?
Brad S
PostPosted: Mon Apr 03, 2006 12:47 pm    Post subject: Reply with quote
I found the relay, it appears good. There is no holes burned in it or anything.
Guess I'll see what the shop guys find.
RockOn
PostPosted: Thu Apr 06, 2006 3:55 am    Post subject: Reply with quote
you can not determine if a relay is good or bad by looking at it.
relays use a coil of wire (like a speaker) and magnatism to operate. Test the thing with you meter. Wink
89 or 90? XJ
Brad S
PostPosted: Thu Apr 06, 2006 10:20 am    Post subject: Reply with quote
Apparently my switch is bad. I'm going to try and pull it out of the dash to replace myself to save money, anyone know of any good ways to do this/ and tutorials that explain?
any help would be greatly appreciated!
RockOn
PostPosted: Thu Apr 06, 2006 9:45 pm    Post subject: Reply with quote
Well my dash is completely different than yours....
Just take your time, be careful not to crack the plastic Wink
89 or 90? XJ
Brad S
PostPosted: Tue Apr 11, 2006 4:09 pm    Post subject: Reply with quote
Alrighty, so I have a replacement switch on the way. Would anyone appreciate a write-up of removing the front dash section on a 95ZJ?
If not, thats cool, but I figured since I'm tearing it apart, I could take some pics and note where screws are..
