Water leaking onto floorboards
Ehunt1
PostPosted: Sun Mar 19, 2006 5:26 am    Post subject: Water leaking onto floorboards Reply with quote
I've got a 98 GC and I'm having trouble with water getting onto the floorboards after a rainstorm. At first it was just in the back, but I sealed the rear window shut and now I'm OK there. Now, however, I've noticed considerable water in my front passenger floorboards and under my right-rear seat (under the jack). I checked the door seals and they're all nice and clean, I can't figure this out. The bad thing is that my Jeep is starting to smell. Anyone got any ideas?
RussellRowell
PostPosted: Sun Mar 19, 2006 6:41 am    Post subject: Reply with quote
Do you use your a/c much? You may have a clogged a/c drain which will cause your floor boards to fill up with water.
1994 w327k
PostPosted: Sun Mar 19, 2006 4:10 pm    Post subject: Reply with quote
Or the heater core could be leaking.. Do you run antifreeze cause if you do you should smell the antifreeze if its the heater core..
azjeepin84
PostPosted: Tue Mar 21, 2006 10:19 pm    Post subject: Reply with quote
I just got done with this problem on my 96 cherokee. After tearing apart the entire dash and carpet and seats i decided the water was coming in from the air inlet on the A/C sytem. And from what i can tell it looks like the grand cherokee has the same set up. The inlet is in the drain tray with the wiper motor. If you want to do a complete fix you can take the plenum out of the car and seal the intake from the interior side. Unfortunatly that means diconnecting the heater core hoses and A/C lines. Other then that you could cut a hole above the intake and weld the hole shut but im not sure how well that would work. I ended up just putting silicone on the backside of the intake that you can reach without taking the plenum out, and i put some around the sponge where the heater core lines come into the engine bay. If you want any more detail let me know and i will try to help. Good luck
