Problem removing back seat
dana129
PostPosted: Mon Mar 27, 2006 12:23 pm    Post subject: Problem removing back seat Reply with quote
Hi guys, I am new to the site, as I have an issue. I want to remove my backseat from my 04 Wrangler. I am a girl, and don't really have any guys to help. can I do it myself, I was trying to figure out how and so far no luck, and words of wisdom would be greatly appreciated.
Thanks!!
Jen2Goofy
Trail Goddess
Trail Goddess
PostPosted: Mon Mar 27, 2006 1:51 pm    Post subject: Reply with quote
I'm a girl and I have no issue getting the seat out. It's not that heavy.
I don't think there has been that many changes, but this how you do it for an 02.
From the back, fold down the seat, the leaver to release the seat to fold it down will be on the left. Then lift it up. On the right side at the bottom of the seat where it joins the floor, where is swivels up there is a pin / clip. Pull that, I think there is only the one clip, but check the other side.
Then just move the seat right or left so the medal part of the seat will come out of the hole attached to the floor.
I'm sure that is clear as mud. If you still can't get it, and no one else can explain it better, when I get home tomorrow I'll take a couple of pictures if I get a chance.
Some people are like slinkeys, they’re not of much use but they will still bring a smile to your face if someone pushes them down the stairs.
www.vajeepgirls.com
www.fm2cd.com
(O||||||O)
dana129
PostPosted: Mon Mar 27, 2006 1:53 pm    Post subject: Thanks Reply with quote
Awesome! I will try it this evening!! I appreciate your help!!
Dana
Lowrider
PostPosted: Mon Mar 27, 2006 2:42 pm    Post subject: Reply with quote
My 2006 is different from what Jen just described. I just removed mine for the first time 2 weeks ago so, in the event that your '04 is like my '06, here's how mine works.
There is a handle right in the middle of the seatback, at the top. Pull it out & up and fold the back forward and the rear seat, bottom & all, will then flip forward.
At the bottom, right at the floor between the two seat tracks, is a long bar that is attached to the seat at the track-runners. Push it down and pull the whole seat assembly back. You might have to push one side of the bar, pull the seat corner backwards, then push the other side of the bar and pull THAT corner backwards.
Once unlatched the entire folded seat assembly will slide toward the rear until it reaches the end of the tracks. Turn the whole seat assembly sideways and lift it out the back of your Jeep.
2006 Wrangler Unlimited
1997 Cherokee Sport 2WD
PostPosted: Mon Mar 27, 2006 7:02 pm    Post subject: Reply with quote
The 97-02 rear seats are different than the 03-06 rear seats.
TJgirl
PostPosted: Wed Mar 29, 2006 8:04 am    Post subject: Reply with quote
I have a 03 TJ and just fold the seat down and pull it out!
I'm a girl too! it's easy Wink
TJgirl Jeeps Rock!
kizer
The Link Meister
The Link Meister
PostPosted: Wed Mar 29, 2006 6:46 pm    Post subject: Reply with quote
Interesting. I guess pulling a pin was to hard and they had to make changes. Wink
Either way the backseat is really light. Im sure even the ladies will not have a problem lugging it around.
Links4Jeeps.com
1600+ Write-ups, and more
My Writeups | My Heap
JLS
PostPosted: Tue Jul 18, 2006 2:51 pm    Post subject: Reply with quote
Can someone post a pic of the rear seat of the 03-06 TJ's, I do not need to see the seat installed just the area it was removed from.
I just want to see what you are talking about...
My 01TJ's seat removes easily... just interested
Thanks
