Exhaust instalation before or after lift ?
Trutrac
PostPosted: Tue Apr 04, 2006 5:56 pm    Post subject: Exhaust instalation before or after lift ? Reply with quote
Im gonna threough on a flowmaster 50 series soon is it Ok to do it before the lift, or will i have to re route the pipe from added inches ??
02' TJ--K&N, Jet stage2 chip, Hella 500, After market Audio. TJ=money pitt
Trutrac
PostPosted: Tue Apr 04, 2006 8:43 pm    Post subject: Reply with quote
if you go 4 in or higher is what im guessing you may have to re route the pipe comming from the header
scorpio_vette
PostPosted: Wed Apr 05, 2006 12:42 pm    Post subject: Reply with quote
i don't believe you need to do any exhaust modifications unless you go with long arm lifts and belly up skid plates. if you put on a short arm lift, the basic layout of everything is still in the same location as it was from the factory, so the exhaust will be fine.
i have a complete borla exhaust on my 97TJ since before i lifted it, and it didn't interfere with the lift at all.
________
Cooking Help
tinybluetj
PostPosted: Thu Apr 06, 2006 6:15 am    Post subject: Reply with quote
I have 5.5-6 in (i forget) It is a SA, and I didn't have to do anything to the exaust. You may as well put the lift on first. Then if you do have to change it, it will be eaiser to crawl under the Jeep! Very Happy
This space has been intentionally left blank
PostPosted: Fri Apr 07, 2006 2:53 pm    Post subject: Reply with quote
If you stay with short arm, 5-link suspension and don't go for a radical tummy tuck, you don't have any exhaust changes to make. Go long arm. Triangulate the uppers or go with a wishbone tri-link, or really tuck your belly, and you'll need to play with the placement of the exhaust components and how the tube it routed.
Stevo02TJ
PostPosted: Fri Apr 07, 2006 4:13 pm    Post subject: Reply with quote
Some lift compaines will make an exhaust kit to re-route your piping.
But for the topic's sake, I'd say wait and lift the vehicle, then make the modifications to the exhaust.
PostPosted: Fri Apr 07, 2006 6:09 pm    Post subject: Reply with quote
$300 later. See what it'll cost you at your local exhaust shop. Probably around $120 out the door with a lifetime warranty.
Stevo02TJ
PostPosted: Fri Apr 07, 2006 6:12 pm    Post subject: Reply with quote
I realized that when I saw the Full-Traction modification...but I was just saying that was an option.
