Maybe I helped this guy
Post new topic   Reply to topic     Forum Index -> General BS
srb96bravo
PostPosted: Fri Apr 07, 2006 5:51 am    Post subject: Maybe I helped this guy Reply with quote
I was outside putting my new brake lines on ( Very Happy , but took a while, one bleeder was absolutley stuck, but got them one, with new speed bleeders) but A guy pulls up and asks if I know about cars. I say sure, some. He says his car won't start unless he gets a jump, then it runs fine, and if he turns it off it will start, but only within the next minute. OK- to me this would be an obvious dead battery as first try. He took it to a shop, this is a foreign man, his english is not very good, but the shop said they tested everything and it was going to be 500$ for a new starter. I was like,what? This guy can start his car if he gets a jump, how can it be his starter. Any way, I told him I was that I would go get a new battery first at a autoparts store, they can help you put in in. You still can't start, at least try another shop. Does this seem to be about the right thing to have said?
PostPosted: Fri Apr 07, 2006 9:47 am    Post subject: Reply with quote
Sure and then charge him $500. rofl
KnightFire
PostPosted: Fri Apr 07, 2006 12:12 pm    Post subject: Reply with quote
Sounds like a dead alternator or battery to me!
You gave sound advice IMHO.
KnightFire
2002 TJ Wrangler X
Patriot Blue 4.0L
Check Website for Mods/Photos
Amsoil Dealer
IBTJn
PostPosted: Fri Apr 07, 2006 12:28 pm    Post subject: Reply with quote
Yea, that's as good a place as any to start. A simple bad cell will drain the others over time...especially on a standard lead acid battery.
And you're probably right. Starters like so many other components either work or they don't work. Not typically intermittently.
Code is right too, should have asked where to send the bill. Very Happy
DozerDan
What the deuce?
What the deuce?
PostPosted: Sat Apr 08, 2006 1:49 am    Post subject: Reply with quote
KnightFire
X2
If it just needs a jump to start then dies after a little while of running it is prob the alt not charging.
get the batt load tested (free at any auto zone) if it is good have them test the alt.
They are fairly honest with you and dont try to dick you around most of the time
qadhafi
Club Moderator
PostPosted: Sat Apr 08, 2006 5:47 pm    Post subject: Reply with quote
I had the same thing happen to me in my Jeep. Turns out it was the combination between a dead cell in battery and a loose wire grounding out in the dashboard. I would get jumped off just fine, but when I shut it off it would not turn back on.
Back from the Dead??
Post new topic   Reply to topic     Forum Index -> General BS All times are GMT - 8 Hours
