no 4 wheel drive
jeepdawg
PostPosted: Sun Apr 16, 2006 4:22 am    Post subject: no 4 wheel drive Reply with quote
I having trouble getting my "89" wrangler Sahara into 4 wheel drive
it doesn't do anything, someone told me I had a bad device that make it go into 4 wheel. could someone help me out
    srb96bravo
    PostPosted: Sun Apr 16, 2006 7:08 am    Post subject: Reply with quote
    1st thing check the linkage on your transfer case. A screw can come loose and then it just slides along a rod under there. Easy to have someone move the linkage and you watch it to see.
    qadhafi
    Club Moderator
    PostPosted: Mon Apr 17, 2006 4:49 am    Post subject: Reply with quote
    Rusty, initally it sounds like you have a bad vacuum shift motor. While it might not be the motor itself, it may be the lines. Here are some things that I found out there on the interweb:
    Similar Issue
    http://www.ultimatejeep.com/Forums/viewtopic/t=2139/view=next.html
    Posi-Lock if you want to ditch the vacuum shift motor entirely.
    http://www.drivetrain.com/4x4PosiLock.html
    Also, I checked with Bryan and he said to double check the vacuum hoses- they should lead to somewhere along the firewall.
    Here are some ebay listings to look at if you do want to replace or repair the vacuum shift parts.
    http://cgi.ebay.com/ebaymotors/JEEP-WRANGLER-DANA-30-FRONT-4-WHEEL-DRIVE-VACUUM-LEVER_W0QQcmdZViewItemQQcategoryZ6763QQitemZ8057318374QQrdZ1QQsspagenameZWDVW
    http://cgi.ebay.com/ebaymotors/JEEP-CHEROKEE-4WD-WRANGLER-4x4-VACUUM-ACTUATOR-New_W0QQcmdZViewItemQQcategoryZ33731QQitemZ8054571513QQrdZ1QQsspagenameZWDVW
    http://cgi.ebay.com/ebaymotors/87-90-Jeep-Wrangler-4x4-Vacuum-Harness_W0QQcmdZViewItemQQcategoryZ6763QQitemZ8056714723QQrdZ1QQsspagenameZWDVW
    Good luck and hopefully someone else around here has had some knowledge on your problem.
    Back from the Dead??
    qadhafi
    Club Moderator
    PostPosted: Fri Apr 21, 2006 5:47 pm    Post subject: Reply with quote
    *Bump*
    So did you ever figure out what it was, Rusty?
