part time light
97XJ Jeeper
PostPosted: Wed Apr 19, 2006 3:01 pm    Post subject: part time light Reply with quote
does all models have the part time 4x4 light? in sunlight i can see that it has it on my dash but every since i got my XJ it has not worked. do they have a low range light? my XJ is a 97. what are the most common reasons for it not work besides the light burnt out? thumbs
JUST PUT IT IN 4X4 AND GO FOR IT!!!
Magnaflow high flow cat
FLOWMASTER SUPER 40
2 1/2" pipe cat back
Videos my XJ
http://youtube.com/profile?user=JeepXJJeeper
JeepinNH
PostPosted: Wed Apr 19, 2006 3:55 pm    Post subject: 4x4 light Reply with quote
I think all of them have some sort of 4x4 light but not all models are the same. I think all mine does is tell you when it's in 4x4 whether it be high or low. There is a switch in the transfer case that is probably sticking in the normal 2 wheel drive mode. Get a manual to locate where it is and trouble shoot the issue. It may just need lubing. I had a Grand that would stick when I first got it because the guy before me didn't use it much. It cleared itself with some use.
Mike
Present: 99 Cherokee
PostPosted: Wed Apr 19, 2006 8:21 pm    Post subject: Reply with quote
As far as the lights, the dash has accomadations for two:
A) Part Time 4WD - Comes on whenever the t-case is in 4Hi or 4 Low. Applies to all t-cases.
B) Full Time 4WD - Comes on whenever the t-case is in Full Time 4WD. Only works on models equipped with NP228/NP229 & NP242 t-cases.
