Rear Upper Control Arm and Rear Brake line question!
Arty155
PostPosted: Thu Apr 27, 2006 12:56 pm    Post subject: Rear Upper Control Arm and Rear Brake line question! Reply with quote
Ok it's only a few weeks away until I put my new lift on my 2002 TJ, (just got done dealing with the insurance over my old CJ7 argh). I decided to crawl underneith and begin to dream about the lift, and continue to dream about running the Rubicon. Twisted Evil Then I noticed that when I replace the Upper control arm I will have to relocate a few lines that are attached to the arm. *shakes head* I also noticed that I may have to relocate where the brake lines are attached to the axle tubes, because of the truss that comes with the lift kit. Does anyone have any good advice on moving these lines to new locations where they will be safe and not in the way, etc.
http://pg.photos.yahoo.com/ph/arty155jln/detail?.dir=/b9f2&.dnm=aad5scd.jpg&.src=ph
http://pg.photos.yahoo.com/ph/arty155jln/detail?.dir=/b9f2&.dnm=1ccascd.jpg&.src=ph
Any help would be great. Thanks
Jeff
PostPosted: Thu Apr 27, 2006 3:04 pm    Post subject: Reply with quote
If you are going with a short arm kit, the lines attached to the upper arms can just fly in the wind. However, with the mention of a truss, it sounds like you're likely going with a long arm kit. You can still let them flap away but I would strongly recommend replacing the rear hose with a longer braided stainless line. Actually, as long as it's a longer brake line, it doesn't matter what it's made out of. But the braided stainless will last longer.
On the truss for my Clayton long arms, the axle end of the brake hose was bolted to the left side of the truss. No pics so you'll have to imagine it.
TJ Apex
PostPosted: Fri Apr 28, 2006 3:53 am    Post subject: Reply with quote
Not only will the stainless last longer, the stainless weaving won't let the hose expand when the pedal is pressed, giving you much better break pedal feel and help cut down your breaking distance too.
2002 Wrangler Apex
02' Apex Edition,
2" BB, 31" BFG AT's
PostPosted: Sat Apr 29, 2006 5:59 am    Post subject: Reply with quote
Not really. The rubber hose used in brake lines today doesn't expand that much. You won't get any noticable improvement in braking due to stainless lines on a late model vehicle.
