Clock????
Ricko70
PostPosted: Mon May 08, 2006 4:47 am    Post subject: Clock???? Reply with quote
I bought a 92 XJ and have wondered about a few things on the dash display.
One is, what is the blank area to right of the speedo cluster for?
It's about 2x3 inches and looks to be a space for a clock or some sort of digital display.
If it.s a clock space, Anyone know where I can get one????
RockOn
PostPosted: Mon May 08, 2006 5:53 am    Post subject: Reply with quote
yes that is for a clock. you could get one (oem, used) off ebay. BUT! you probly will not have factory wiring for the clock. So you will need to run wiring for it.
sorry I have no idea what wiring is needed. It may only need a pos & a neg.
I'm sure it would not be to hard to find a 12v clock that could be installed in that area with some dremel work
89 or 90? XJ
Ricko70
PostPosted: Mon May 08, 2006 1:11 pm    Post subject: Reply with quote
Thanks, I'll look on ebay I don't think the wiring would be too much of a problem----I hope---famous last words
MachineMan
PostPosted: Mon May 08, 2006 3:40 pm    Post subject: Reply with quote
On my '90, the clock is just above that blank space and behind the blank space is the circuit board for it. Go get one of those little round LCD clocks with the adhesive on the back and stick it there. Or you can cut a 2" hole in it and put guage there.
Check here: http://www.go.jeep-xj.info/HowtoDashClock.htm
