Wiring short circuit?
dancj7
PostPosted: Wed Apr 26, 2006 4:23 am    Post subject: Wiring short circuit? Reply with quote
Hi folks! I'm new to this forum and looking for some help, perhaps you can help me out with some ideas. I've got an '85 CJ7 and when I moved the vehicle from one side of the driveway to the other side I had no problem starting and moving the jeep. Later, when I went to start and move the jeep back to where it was, it wouldn't start. It'll crank but won't turn over and run.
I keep blowing the 5amp fuse in the "Ign Lps" slot of the fuse box under the dash. I replaced the ignition switch and then the module thinking they may have been bad internally but still no fix. Any ideas? Thx.
frozencircuit
PostPosted: Sun May 21, 2006 7:04 pm    Post subject: Reply with quote
i would try to replace your wiring harness it sounds to me like its .. on a start to going bad. the wiring harness's on cj's are bassically all the same you can bassically throw in one from a ford without doing any harm. the harness's do tend to burn a hole in your pocket so if money is an issue i would strip one from a junkyard.
dancj7
PostPosted: Mon May 22, 2006 2:19 pm    Post subject: Reply with quote
Thanks for the tip. One thing I later found out is that there should be a 15amp fuse in place of the 5 amp. Another thing I later realized is that the fuel guage stopped working. Don't know if there is a connection between the two but I think I'll drop the steering column and dash and check the wiring inside the dash for problem areas.
