Couple grand cherokee questions!
omega1300
PostPosted: Sun Jun 18, 2006 4:32 pm    Post subject: Couple grand cherokee questions! Reply with quote
I currently have a 97 cherokee (XJ) but am thinking of moving up to a grand, as I'm a bit too tall, and my legs don't really fit in my cherokee all that well. So my questions are:
For the years 97-2000 what 4x4 transfer case should I be looking for to get the best offroading ability? I have select-trac in my XJ (2wd, 2wd part time, 4wd full time, 4wd low) and really like it, as it allows me alot of options, but is there one that is superior?
As well, I have heard that the V6 does not save much gas over the V8, and that you should go for the V8? I'd like the extra power and towing ability, but how is it on gas?
Any years between 97-2k that are superior or have any major improvements I should be looking for?
thanks alot guys! I really appreciate your help!
omega1300
PostPosted: Mon Jun 19, 2006 9:31 am    Post subject: Reply with quote
anyone? Smile
omega1300
PostPosted: Mon Jun 19, 2006 7:28 pm    Post subject: Reply with quote
Just looking for GC owner's experiences with their Jeeps/opinons here, they don't have to be facts! Mr. Green
Bishops Finger
PostPosted: Tue Jun 20, 2006 7:30 am    Post subject: Reply with quote
Got a 98 with permanent 4wd via Quadra drive system
6 Cylinder engine and pretty happy with it...deffo more room than an XJ
PostPosted: Tue Jun 20, 2006 8:03 am    Post subject: Reply with quote
mines a 94
if you find one from the 93-98 years the ZJ body style they tend to be a bit cheaper
98 gives you the 5.9 option, or you could get the 5.2 or the I6
the I6 is pretty stout motor, i like it i havent had any problems with it yet
as for the drivetrain if you can find one without the full time 4wd option especially if your going to wheel it
as for towing id def get a v8, if you do find one from the 93-98 years the 5.2 gives you 3.73 gears
unforgiven
PostPosted: Tue Jun 20, 2006 1:48 pm    Post subject: Reply with quote
hey , my wife is jest a lil gal an im 6'2 so i can agree on the problem our first jeep was an 88 xj long story short the day after we got it the engine went so in goes new motor and out i go to buy another
but this time its a 97 zj 5.2 l it'll fix yer problem for sure. and its fun ta boot lol
hope the opinion helps ya judge
omega1300
PostPosted: Tue Jun 20, 2006 2:16 pm    Post subject: Reply with quote
thanks for the replies guys, this is exactly the info I was looking for!
Unforgiven : I'm 6'2" - 6'3" as well, you fit in your zj well?
1fox2go: you said if im looking to wheel a bit, look for one w/o full time 4wd, would the select-trac be a good option? (it allows you either full time or part time 4wd, 4w lo and 2wd) or are you talking more of the command-trac type?
thanks again everyone, really appreciate it
PostPosted: Tue Jun 20, 2006 6:14 pm    Post subject: Reply with quote
find one that has the 2wd option either way if your goin to wheel or not
it helps gas mileage a bit as wheel as easier on the drivetrain
if you cant find one that way however its a very common and fairly easy swap to change transfer cases
the cases you would want are 231 or 242
unforgiven
PostPosted: Tue Jun 20, 2006 7:04 pm    Post subject: Reply with quote
eah omega im 6'2 and no probs fittin in
but definately i want to get a different t-case wanna have that 2whl option
