93 xj hard to start cold
935speedxj
PostPosted: Sun Jun 18, 2006 7:13 pm    Post subject: 93 xj hard to start cold Reply with quote
93 xj is hard to start when it is cold an wont idle untill warm all new sensors an newer fan works when you unplug the sensor on the thermostat houseing but turns back off when you plug it back in . an my temp guage does not work new guage an sensors an the relays work .. does anyone got a idea on whats wrong? thanks ~ phil Sad
ROJO13
PostPosted: Fri Jun 23, 2006 1:30 pm    Post subject: Reply with quote
We had the same problem on our 2 1999 xj's. First we got tune ups then changed the fuel pump on one. That did not work. We then changed both batteries. That worked. No cranking power. With the old bat When the car finely got started and up to 209 it would idle fine but was hard to start. It just took a new mopar bat to fix it. Change them every 4 years.
935speedxj
PostPosted: Sat Jun 24, 2006 7:04 pm    Post subject: Reply with quote
no it has plenty enough cranking power cranks just fine to be honest just wont idle until it warms up like the computer is confused or something angry ive tried everything i can think of all new sensors new fan .... just wont idle for some reason?? pissed
ROJO13
PostPosted: Sat Jun 24, 2006 10:48 pm    Post subject: Reply with quote
Ours had or acted like it had cranking power. It also charged fine? New bat no more problems?
CoreyXJ
Turkish
Turkish
PostPosted: Sun Jun 25, 2006 9:03 am    Post subject: Reply with quote
Most of the time when you have an idling problem its because the Idle Air Control motor has carbon build up in it or it just plain and simply stopped working. The IAC motor is on the side of the throttle body opposite the throttle position sensor. Have you replaced that?? In extreme cases it could be a combination of both the TPS and IAC motor....
CoreyXJ
935speedxj
PostPosted: Sun Jun 25, 2006 9:10 pm    Post subject: Reply with quote
CoreyXJ
i have cleaned the throttle body many of times an they both are new ( sensors)
PostPosted: Sun Jun 25, 2006 9:22 pm    Post subject: Reply with quote
Okay, so you've cleaned the throttle body, but have you verified your IAC is working?
94BGCherokee
PostPosted: Sun Jun 25, 2006 10:20 pm    Post subject: Reply with quote
Does it still idle bad when its warm? Does it overheat? Does the vehicle idle rough period? No check engine lights? So when its hard to start you hold the idle to keep it running. Let me know what goes on with it, if it overheats and barely runs, could be head gasket, if it runs like shit even when its warm, just could need a tuneup. If there has been a check engine light on before you should check memory codes and that might give you something to go off of. Hope this helps
935speedxj
PostPosted: Mon Jun 26, 2006 6:18 pm    Post subject: Reply with quote
well no it runs just fine when it is warm.... no it does not over heat an i replaced the head gasket along with alot all the other gaskets..dancing banana ...just when the jeep is cold.... soapbox when it is cold out it wont idle for about 5 mins till it is warm...( have to keep foot on gas to keep it to idle) warm weather it is about 30-45 seconds before it will idle.... i replaced the iac an tpc sensors..... dont know or not if the iac is workin properly....pull hair . dont know how to check that sensor.... any ideas man bowdown ty ty ~ phil
