Diff Fluid?
dwarf66
PostPosted: Wed Jul 12, 2006 6:43 pm    Post subject: Diff Fluid? Reply with quote
I changed the fluid in the rear on a 99 Wrangler. I tied to do someone a favor. I used Mobile synthetic 75/90. The driver said the rear burned up and is at another shop which is telling her that I put in the wrong fluid. She is looking to get compensated for a rebuild. What fluid does this vehicle take? I am very suspicious. Thanks
scorpio_vette
PostPosted: Thu Jul 13, 2006 5:25 am    Post subject: Reply with quote
DIFFERENTIAL FLUID TYPE
181 FBI, 194 RBI, 216 RBI
Multi-purpose hypoid gear lubricant meeting the following specifications:
-- MIL-L-2105C
-- API GL 5
-- Thermally stable SAE 80W-90 gear lubricant
Lubricant for heavy-duty or trailer tow use is SAE 75W-140 SYNTHETIC gear lubricant.
TRAC-LOK
If equipped, include friction modifier.
this is directly from alldata service manual.
________
Ford Meteor specifications
PostPosted: Thu Jul 13, 2006 8:14 am    Post subject: Reply with quote
There's nothing wrong with using 75W-90. As stated above though, if the diff is limited slip (TrakLok), then friction modifier should have been added.
