A/C Pressure High
chris7874
PostPosted: Thu Jul 20, 2006 11:53 am    Post subject: A/C Pressure High Reply with quote
I have 2003 Jeep GC Laredo. My A/C has been working intermittently. From reading various posts I figured I was low on refrigerant since the correct running psi should be around 45 psi and mine was around 20 . I bought a can of R134A with the built-in gauge at Autozone and added some myself; however I may have overcharged the system. The psi on the low-side port with the engine running, the a/c on max and the ambient temperature over 90 degrees is 70 psi now. Now the compressor stops after about a minute of running (most likely due to the high pressure switch being tripped) and won't come back on again unless I turn off the car and wait a while for the pressures to equalize. Without taking it to a shop and pay big $$$ to have them due an evacuation and recharge, how can I reduce the pressure to where it needs to be? If I press the schrader valve on the low or high side port for a few seconds , will that bring it down? Or will it just let more air into the sytem?
PostPosted: Thu Jul 20, 2006 5:56 pm    Post subject: Reply with quote
Yes that will bring it down..
Go for it..
