Cherokee hard to start
Gryphon
PostPosted: Sun Jan 29, 2006 8:41 pm    Post subject: Cherokee hard to start Reply with quote
This is my first post, but I've searched the site and couldn't find an answer to my question. I have a 98 Cherokee sport and it has a wierd problem. If it is cold, it starts fine. If it is warm (it has been running in the last 1/2 hour) it starts fine. Anything in between that it is hard to start. It turns over fast, but it will not start unless I engage the starter, let off for a second and engage the starter again. I've replaced the plugs and wires and the air cleaner. I checked the self diagnostics and nothing comes up. I don't want to keep guessing what is wrong and buying parts to see if it will work. I'm hoping that you guys have some suggestions of what I should do next. Any ideas?
Lowrider
PostPosted: Sun Jan 29, 2006 8:44 pm    Post subject: Reply with quote
My '97 Cherokee acted the same way. It got harder and harder to start until it finally just quit running one day as I was driving down the street. Turned out to be the crank-position sensor.
2006 Wrangler Unlimited
1997 Cherokee Sport 2WD
Gryphon
PostPosted: Mon Jan 30, 2006 9:25 am    Post subject: Reply with quote
Did you replace the sensor yourself? If so, can you tell me where it is and if there is a way I can test it? Thanks for the help.
Lowrider
PostPosted: Mon Jan 30, 2006 9:55 am    Post subject: Reply with quote
No, I didn't do the work myself. I had to have it towed to the dealership and they diagnosed it and replaced the sensor.
They are easy to replace if you could be sure that's what the problem is. It threads into the engine near the bottom of the timing cover.
My trouble began just like yours, where it wouldn't start on the first try no matter how long I cranked it. But turn the key off, wait a few seconds, hit it again, and it would start right up. It progressed from there to where I'd half-drain the battery trying it again and again until it finally fired up.
Then it just started working normally again, starting immediately without problems for a couple of months, and one day as I was slowing to pull into a parking space it quit running, just like I'd shut off the ignition, and it absolutely wouldn't start again, even after I left it for several hours before trying it again. The next stop was the shop.
I believe they charged me about $150 for the sensor and another hundred and some to do the diagnostic work and the actual sensor replacement. Total bill was a little over $300.
Gryphon
PostPosted: Mon Jan 30, 2006 3:40 pm    Post subject: Reply with quote
That sure sounds like it could be the problem. I wish that there was a way to test the sensor. I would gladly pay the $150 for the sensor if I were sure it was the culprit. The only thing that bothers me is that there is an error code for a bad crank sensor, but my Jeep isn't showing it. Maybe I'll just take the sensor off and see if I can clean up the contacts.
JeepinNH
PostPosted: Mon Jan 30, 2006 8:14 pm    Post subject: sensor Reply with quote
I had a similiar issue with my Grand Cherokee but it was the one in the distributer. From what I remember the 4.0 has 2 of these hall effect type sensors. I was able to check mine with a volt meter. The old Hanes manual actually listed how to test it. Basically 5volts and 0 volts while the engine is turning. Mine was stuck in the middle somewhere, at least when it wouldn't start. It was a painless replacement that cost about $60 for the part.
Mike
Present: 99 Cherokee
Gryphon
PostPosted: Wed Sep 06, 2006 2:59 pm    Post subject: Reply with quote
Could you elaborate on how to test the sensors? I have a voltmeter but no hayes manual. This problem hasn't gotten any worse, but it hasn't gotten any better. I fear that one day it's just gonna quit and strand me somewhere. I'll probably replace the CPS since that seems to be a problem on a lot of high milage 4.0's Before I do that though, I want to test the dist sensor.
PostPosted: Wed Sep 06, 2006 4:55 pm    Post subject: Reply with quote
It sounds like you have a classic CPS problem. If the reference signal for either the crank or cam position sensor shorts to ground, the PCM will go into a safeguard routine and shut down to protect itself. Since the PCM is now essentailly turned off it will not store a fault code (DTC). Even if the short is momentary, the engine will not start until the ignition is cycled back to the LOCK postion, resetting the PCM.
The test for both the the crankshaft and camshaft position sensors are the same. With the engine cranking, check the voltage from the orange wire to ground. The voltmeter reading should cycle from 0 volts to about 5 volts. If it doesn't cycle, the sensor is bad. If you're using a digital voltmeter, crank the engine a very small amount at a time. Digital meters do not react instantly, so it's tough to see the change in reading if the engine is cranked continually.
However, this only works if you can test for the problem while it's happening. Most CPS problems manifest themselves as momentary shorts and will test good the rest of the time.
Gryphon
PostPosted: Wed Sep 06, 2006 7:50 pm    Post subject: Reply with quote
I tested the sensors and they seemed to be working fine. I would get both 5 and 0 volts. Nothing in between. But, this problem doesn't always happen. Sometimes the Jeep starts just fine. What should I do? What is the most likely culprit? What should I spend my money on first?
Thanks.
PostPosted: Wed Sep 06, 2006 8:40 pm    Post subject: Reply with quote
The most likely culprit is the Crank Position Sensor for the reasons stated above. Based on your description, they exactly match the symptoms you are seeing.
Gryphon
PostPosted: Thu Sep 07, 2006 5:51 am    Post subject: Reply with quote
From what I've read, you're a guy who knows his stuff. Crank sensor it is then. I'll replace it this weekend and post the results.
Thanks
Gryphon
PostPosted: Wed Sep 20, 2006 5:29 am    Post subject: Reply with quote
I replaced the crank sensor and it wasn't the problem. My father in law has a good friend that owns a shop and offered to have a look at it. It turns out that there are parts in my fuel pump that are going out. There is something like a check valve that is supposed to hold pressure in the fuel lines even while the Jeep sits. Mine takes about 2 hrs for the pressure in the fuel line to drop to zero. It would cost me about $350 to buy a new fuel pump, but my FIL's friend said that he would just live with it. It shouldn't cause any more problems and there's no reason to believe that it will strand me somewhere. I just thought I'd let you guys know what I found in case anyone else were having the same problem.
