OMIT ABS BRAKES
zjrocks
PostPosted: Tue Aug 29, 2006 7:39 pm    Post subject: OMIT ABS BRAKES Reply with quote
I have a question for you guys? I have put in a super 35 on my zj that came out of a tj lost my rear abs. That to me is ok don't realy like the thought of the computer controling my braking anyway. I'm now ready to swap out my front axls from cv to ujoint. Unpluged front abs now my brakes don't feel right. Do i need to change out my portioning valve or what? Rolling Eyes
zjrocks
PostPosted: Thu Aug 31, 2006 3:43 pm    Post subject: Reply with quote
I's there anyone that can help me please !!! i just want to disconnect my ABS . Has anyone disconnected them that would be willing to give me some advice? I would appreciate any help i could get. thank you.nick
PostPosted: Thu Aug 31, 2006 7:46 pm    Post subject: Reply with quote
SOrry.. I didnt respond sooner.. YOu can get rid of the crap ABS.. Pull the fuse and the relay.. And you should be fine..
You shouldnt have to unplug the ABS pump.. If you do unplug the pump you will probobly have to change prop valve and pull the pump all the way out..
I have 4 wheel disk and can lock my tires up .. I will check to make sure my pump is plugged up and let you know..
I got rid of my ABS about 5 or so years ago so memory is a little fuzzy...... Mr. Green
zjrocks
PostPosted: Sat Sep 09, 2006 7:09 pm    Post subject: Reply with quote
Thank you carl for your reply.I have allready unpluged my abs so far everthing seems to be ok. I hope that i didn't hurt anything.I just want to thank you for all your help and advice and time that you take to help everyone.nick
PostPosted: Sun Sep 10, 2006 7:19 pm    Post subject: Reply with quote
Yeah.. I checked mine and it is unplugged.. I have no problem locking up the tires when I step on the brakes..
