Can a bad gas cap cause this?
IndyMatt
PostPosted: Wed Sep 13, 2006 4:55 pm    Post subject: Can a bad gas cap cause this? Reply with quote
Referring to my problem in this thread: http://www.jeephorizons.com/phpbb/viewtopic.php?t=9337&sid=003c8366386a5c25175af2c7ab765aed
I've been through several fuel pumps recently. I think this latest time I narrowed it down to the fuel relay however; intuition tells me this may not be the root cause of the problem. In another forum that I belong to, someone mentioned that if the gas cap is not allowing the tank to breathe, then this could very well result in the symptoms I've been getting with this Jeep (running sluggish, no power, 15psi fuel rail pressure).
I'm curious if anyone here has had experience with a bad gas cap not allowing the tank to breathe. Please share.
Thanks- Matt
PostPosted: Wed Sep 13, 2006 5:27 pm    Post subject: Reply with quote
I don't think so. If the cap was bad you would get a check engine light, but I doubt it would eat fuel pumps. The cap doesn't allow the tank to pressurize...just the opposite actually...it needs to be able to hold a vacuum. That's how the EVAP system makes sure there are no leaks in the tank.
IndyMatt
PostPosted: Thu Sep 14, 2006 3:51 am    Post subject: Reply with quote
Thanks for the feedback. I still haven't put very many miles on it since the latest pump install...we'll see how things go.
Matt
kaos
PostPosted: Fri Sep 15, 2006 1:46 am    Post subject: Reply with quote
I'm not quite sure of my facts here, so take this with your preferred dose of salt, but: While Phantom is right in that some amount of vacuum in the fuel tank is normal, and should not be released by the fuel cap, surely this is regulated somehow? I *think*, however, that this is done through a breather line to the evap canister in the engine bay, rather than by the gas cap. You might want to check that this line is free of obstruction / unkinked.
Best regards,
Kári, in Iceland.
94z07
PostPosted: Sat Dec 16, 2006 10:23 pm    Post subject: Reply with quote
IIRC the gas cap is NOT supposed to breathe.
There is a line that runs to the canister in the engine compartment that vents the gas tank.
Look at a snorkle kit and you'll see that this is one of the things that ppl route up high so they can go jeep swimming.
