97 ZJ ABS blues
MI jeep zj
PostPosted: Sat Sep 16, 2006 3:28 pm    Post subject: 97 ZJ ABS blues Reply with quote
The ABS on my 97 ZJ seems to engage under normal stoping just under 5 mph. I installed new disc and pads, had sensors checked but no luck. Any help would be great. Thanks
PostPosted: Sun Sep 17, 2006 1:13 am    Post subject: Reply with quote
Did they check the air gap on the sensors? Somewhere or other I read about the same problem you were having and the air gap was a small bit off on one of the sensors.
MI jeep zj
PostPosted: Mon Sep 18, 2006 3:46 pm    Post subject: Reply with quote
I FOUND IT! In the process of checking the air gap on the sensors I found a flat spot on the front ABS Ring. (looks like someone hit it with a hammer while replacing the U joint (not me by the way). Thanks for the help.
