exhaust manifold
JeepinNH
PostPosted: Sun Sep 17, 2006 7:42 am    Post subject: exhaust manifold Reply with quote
Hello, it seems I have a small crack on my exhaust manifold where the 2 sections meet. It is parallel with the weld. Is this common? I did a quick search with no hits. I'm thinking some sort of high temp putty to fill it in. It looks weldable but a PIA to remove. Thoughts?
Mike
Present: 99 Cherokee
88WOWJ
PostPosted: Sun Sep 17, 2006 11:45 am    Post subject: Exhaust Leak Reply with quote
Yes this is problem but very little. My 1988 exhaust manifold was cracked
in numerous places but was not leaking. It had 225,000 miles when the engine was replaced. The dealer wants way to much money for repalcement, $500.00 plus. I would go headers before paying that much.
Check out this site maybe it will help http://www.carpartstoyourdoor.com/jeepexhaust3.htm
And no you cant weld it as it is stress cracked and the metal will just crack again.
1991 Cherokee Limited
JeepinNH
PostPosted: Wed Sep 20, 2006 6:44 am    Post subject: manifold Reply with quote
Wow, that's a cheap price. Has anyone tried one? Is it a quality unit?
Thnaks.
Mike
tomynoks
PostPosted: Fri Sep 22, 2006 11:50 pm    Post subject: Reply with quote
Check EBay.. you can get that header for under $100.00 shipping included...BUT I would recommend you check this one out for about $135 w/ shipping:
http://www.autopn.com/store/pc/viewprd.asp?idProduct=20009
It's almost identical (I can't tell the difference) to Banks Header selling for hundreds more.
http://www.savannajones.com/Assets/Images/36419/36419-lg.jpg
'99 XJ Sport
AirAid Intake
PowerAid Throttle body spacer
RE6030 3.5"
1" T-case drop
31x10.5x15 BFG AT KO's
gtouimet
PostPosted: Mon Sep 25, 2006 9:24 am    Post subject: Reply with quote
You could check these out too.
http://www.quadratec.com/products/17604_102_07.htm
http://www.quadratec.com/products/17604_101_07.htm
http://www.quadratec.com/products/17604_100_07.htm
http://www.quadratec.com/products/17602_300_07.htm
'91 XJ, 8" lift, 35x12.5x15 BFGs, 8.8, 4.56
tomynoks
PostPosted: Tue Sep 26, 2006 9:24 pm    Post subject: Reply with quote
The one I bought is EXACTLY the same as the ones from Quadratec, but for only $135.00 shipping included...... Quadratec ? $299.00
'99 XJ Sport
AirAid Intake
RE6030 3.5"
1" T-case drop
JeepinNH
PostPosted: Wed Sep 27, 2006 5:14 am    Post subject: manifolds Reply with quote
The Quadratecs are really nice to look at but you can hardly see the manifold so for the price why bother? Right now I have liquid steel on there and it seems to be holding up. I need it to pass inspection this month then I'll have time to figure out what to do next. Thanks.
Mike
JeepinNH
PostPosted: Tue Oct 03, 2006 1:54 pm    Post subject: manifold Reply with quote
Well, the liquid steel lasted about a week so I just ordered the one tomynoks listed. It looks like it's good quality and has better flow characteristics than the other one. We'll see. I watched the crack today, when the engine is cold it's open and as it warms up it closes (be nice... Wink ). I did some Googling and it seems alot of people are complaining about this issue.
Mike
JeepinNH
PostPosted: Sun Oct 15, 2006 10:38 am    Post subject: manifold replaced Reply with quote
Hello, I bought the manifold that tomynoks listed. Looks decent and was not too much of a pain to install. It took me 4 hours start to cleanup. I was amazed that all the fasteners came off without drama. The only issue I had was the down pipe near the firewall was hitting the intake. Because of this the intake would not seat properly. I removed some metal from the intake and flattened the pipe a little with a hammer. That was enough for it to fit perfectly. I haven't noticed any significant changes in sound or power, maybe a little smoother on the power. We'll see if fuel economy is better. Here is a link to some pictures of it. http://mysite.verizon.net/vzeqtxwy/
Mike
TheBrat97
PostPosted: Sun Oct 15, 2006 1:47 pm    Post subject: Reply with quote
I'm sure we've all noticed this but how is an XJ manifold much different from a header? It has smooth flowing tubes like a header so I was just wondering.
JeepinNH
PostPosted: Tue Oct 17, 2006 6:01 am    Post subject: header Reply with quote
I'm not really sure of the difference between a header and a manifold. I always figured manifold is a cast iron type unit and header is tubular steel. If this is the case then the stock one would be a header. I think a header fits into the "manifold" classification but not the other way around. Either way the stock one sux Mr. Green
Mike
TheBrat97
PostPosted: Tue Oct 17, 2006 9:36 am    Post subject: Reply with quote
The stock Jeep manifold is the first stock manifold I've ever seen that looks so much like a header.
