got some problems
98CherokeeLTD
PostPosted: Mon Sep 18, 2006 7:39 pm    Post subject: got some problems Reply with quote
got a few things goin on here...
my g/f has a 98 cherokee limited and some things are screwy
#1. reverse lights are really tempermental...sometimes they work and sometimes they dont
#2. her gauges sometimes stop working and the airbag light comes on..usually honking the horn gets the gauges to work again and airbag light turns off
#3. a/c works when it wants to..its full of freeon and the motor idles up when you turn the ac on but the clutch for the condenser doesnt always engage so a/c doesn't work
#4. lastly, the rear washer stopped working...wiper works though. the sprayer isnt clogged so.
Any help would be a great help thumbs ...Thanks
01xj
PostPosted: Fri Sep 29, 2006 2:17 pm    Post subject: Reply with quote
Did you have any recent electrical work done? If so, that's where I'd check first. Could be one little thing causing the whole mess.
tag
PostPosted: Sun Oct 08, 2006 5:24 am    Post subject: Reply with quote
Hi,..
had the same problem with the rear wash wipe, after investigation it turned out to be the pipe that feeds the water to the rear had come apart at the joint were it comes through the firewall. this pumped water under the carpets! it's very close to the fuse box and relays in the footwell. Check for water in your footwell........just a thought.......cya Wink
