emergency brake lever broken... fixes?
black97xj
PostPosted: Sat Sep 23, 2006 2:33 pm    Post subject: emergency brake lever broken... fixes? Reply with quote
i pulled the ebrake lever up too far to get a better angle, in order to remove the center connsole. the plastic button on the top snapped off, and now the lever won't stay engaged... anyone ever experienced this and/or know of a good way to fix it without getting a whole new mechanism from a junkyard? thanks.
offroading.net
PostPosted: Sat Sep 23, 2006 2:37 pm    Post subject: Reply with quote
I have had mine pop out, they are a bitch to fix. Has the male piece in the button snapped off inside the handle? If so I'd say get a second hand one
Steve Wright
steve@offroading.net
pipxj
PostPosted: Sat Sep 23, 2006 2:52 pm    Post subject: Reply with quote
You'll have to replace the entire handle. Had this problem about five years ago. I didn't enjoy the fact that I couldn't use the E-brake so avoided parking on any hills.
black97xj
PostPosted: Sat Sep 23, 2006 2:59 pm    Post subject: Reply with quote
when i look inside the plastic button for the end, i can see what looks to be the female piece has broken off... i'm left with a threaded metal bolt. if i play with the bolt, i can get the brake to work, but it's just kind of a pain. i figured it probably wouldn't be too hard to replace the whole thing, i'm just mad at myself for breaking it in the first place. thanks for the info!
pipxj
PostPosted: Sat Sep 23, 2006 8:58 pm    Post subject: Reply with quote
Yeah, the button on mine popped out while driving down the highway. Scared the crap out of me and I couldn't figure out what it was.
chaco873
PostPosted: Tue Oct 24, 2006 10:59 am    Post subject: Reply with quote
Well this just happened to me. Found the button in my seat. I have removed all if the center console to get at this thing, and now I need to know how this thing works. I have a button, a metal rod with a hook/curve on the end, and a cantelever that engages the teeth on the parking brake. how do these things connect? Is there supposed to be a spring anywhere? Does anyone have a suggestion of who sells these besides the junkyards or dealership?
