Auto box noise
offroading.net
PostPosted: Sat Sep 23, 2006 12:09 pm    Post subject: Auto box noise Reply with quote
Its done 130k miles now and getting a bit noisey, not too bad but I notice it. I have swapped out the oil but no difference (didn't have time to do the filter at the time, is it worth doing?).
Should it be expected to be whining slightly at this mileage? change was much improved with the oil change and it isnt leaking.
Steve Wright
steve@offroading.net
quadna71
PostPosted: Sat Sep 23, 2006 12:48 pm    Post subject: Reply with quote
changing oil and not the filter is sort of a waste of time. no point in putting clean oil in when your filter is probably clogged up from the first run through.
that being said an oil change won't usually quiet down an engine that is tapping or knocking. either it's not happy with the gas you're feeding it, the timing isn't quite on, or you just have some lifter issues. sometimes a quick can of those off-the-shelf engine restorers help as a bandaid...but sooner or later you may need some more expensive work.
chris (have 174k on the xj, some tapping, but still going strong)
2003 TJ Sport
offroading.net
PostPosted: Sat Sep 23, 2006 2:27 pm    Post subject: Reply with quote
deffo the auto box, engine is fairly noise free. Will get myself a filter and change the oil again
Steve Wright
dizzymac
PostPosted: Thu Sep 28, 2006 9:29 pm    Post subject: Reply with quote
throw a quart of MMO (Marvel Mystery Oil) in it and run it for a couple of weeks and see if you notice a diff.
