Differential fluid? Friction Moddifier?
stilfx
PostPosted: Mon Oct 09, 2006 6:53 am    Post subject: Differential fluid? Friction Moddifier? Reply with quote
I have an 03 I6 4.0 Cherokee Laredo and its ready for a Differential fluid change... But I'm a bit confused as to which gear oil to use and where to buy them? It also says I need a friction modifier (4oz), no biggie, but where do you get it?
Any links to specs / online stores would be great.
Thanks
The nicest thing about smacking your head against the wall is the feeling you get when you stop.
[url]ATVstore.com[/url]
PostPosted: Mon Oct 09, 2006 9:08 am    Post subject: Reply with quote
I'd look at Redline Oil - 75W140 gear oil. It doesn't require the additive. If you end up going with something else, your local parts store should have the additive you need. If you have trouble finding Redline, you can buy it at http://summitracing.com/
quadna71
PostPosted: Tue Oct 10, 2006 5:13 am    Post subject: Reply with quote
yup, napa carries the friction modifier in 4oz. bottles.
2003 TJ Sport
stilfx
PostPosted: Wed Oct 11, 2006 9:22 am    Post subject: Reply with quote
Thanks guys!
Will I need a hand pump, or is there enough room under there... Last time I changed this was 10 or so years ago on my old CJ-7. The cherokee doesnt look so spacious..
Any links to get one online?
...great forum, thanks!
PostPosted: Wed Oct 11, 2006 9:25 am    Post subject: Reply with quote
Not the best photo, but this is what I use. I can't even remember where I got it, but Napa or similar should have something like it.
jakster
PostPosted: Sun Oct 29, 2006 6:17 pm    Post subject: Reply with quote
AMSOIL makes some great stuff for the rear it will make it geaqrs slippery and quiet them down as well. I am a dealer or go to amsoil.com my email is windrider@surfglobal.net I will need you to email me and I will order it you pay with your card. All orders usually ship from the warehouse some dealers carry it in stock.
2005 Grand Cherokee ,white,V6 Stock but fun and great ride.
Zj95maxx
PostPosted: Sun Oct 29, 2006 7:31 pm    Post subject: Reply with quote
go here.. http://www.vaxc.org/phpBB2/viewtopic.php?p=74306#74306 scroll down, i did a write up on diff change
