Scheduled maintenance for Rear Differential Fluid
dwd651
PostPosted: Mon Oct 30, 2006 7:22 am    Post subject: Scheduled maintenance for Rear Differential Fluid Reply with quote
I have a 2005 Grand Cherokee with 30,000. I took it in last week to have front end balanced, and they told me I needed to have my Rear Differential fluid changed for a cost of $300.00 They checked the fluid and said that it was dirty using their "this is your oil--this is how it should look" sample. I have not noticed any leaks and never asked that this be done----is this legitimate or just a case of the dealer trying to make a buck?? thanks for your opinions
PostPosted: Mon Oct 30, 2006 9:16 am    Post subject: Reply with quote
Just pull the inspection plug and check the condition of your fluid. If it needs to changed you can do it yourself for the cost of the fluid. Depending on what fluid you buy you'll save at least $275.
PostPosted: Mon Oct 30, 2006 11:12 am    Post subject: Reply with quote
What interval does your owners manual list? Do you have a warranty that requires certain maint. to keep from voiding it? That doesn't seem like an unreasonable mileage for that service and you're not going to have much luck figuring it out by looking at the oil unless you have metal shavings and/or obvious water contamination. But, I wouldn't pay $300 to have it done. It's a bit messy but not hard. http://jeephorizons.com/tech/diffoil.html
