Heater Question ????
TAEIA && JEEPGUY
PostPosted: Tue Oct 31, 2006 12:59 pm    Post subject: Heater Question ???? Reply with quote
2000 Jeep TJ having problems with our heater, we can only use it on the medium-low setting. This is a new problem that started this last weekend, before that everything was working fine. This is a new heater as of March 2006 (we replaced the whole heating unit and parts) if you have any advise on how to fix this please let us know....thanks
Last edited by TAEIA && JEEPGUY on Wed Nov 01, 2006 8:48 am; edited 2 times in total
KarlVP
PostPosted: Wed Nov 08, 2006 10:29 pm    Post subject: Reply with quote
There are a few problems with TJ's and the knobs. Most 2K+ require knob replacement. I could be your resistor though.
luckylynnd
PostPosted: Thu Dec 14, 2006 2:19 pm    Post subject: Reply with quote
If you haven"t figured this out yet maybe this will help. I just replace the fan control swx on my 00TJ. Only speed 3 was inop. Remove the control panel. Remove the connector from the back of the swx, with a jumper wire you can experiment to see if all the fan speed work by jumping from the brown wire (hot) to the other positions. If they all work the swx is bad. remove the swx retainer screw in the back,1/4 hex, with a flat screw driver pry the swx up just enough to move the knob a little, be careful here, replace the swx, knob etc. in reverse order. If you cannot get all speeds to work from the swx connector the next place is the risistor pack.
