"snap crackle pop" right here! ANY SUGGESTIONS WEL
DankNesS
PostPosted: Sun Oct 29, 2006 10:15 am    Post subject: "snap crackle pop" right here! ANY SUGGESTIONS WEL Reply with quote
hey jeeperz my 93 zj is a clankity clankn in the parkinglot under 10mph when ever i turn it will pop and clank im sure you all got your ideas and/or experiences so please share them. ive been looking through the past posts and havent quite found this so i will keep looking any and all help is GREATLY appreciated!!!
PS also when offroading over bumps i hear i high pitched eech eecch coming from both front and rear... i just lifted her so maybe shocks? tires dont seem to be rubbing... is it all g?
THANKS AGIAN GUYS YOU ALL ROCK!!!
briguy2kgc
PostPosted: Sun Oct 29, 2006 10:20 am    Post subject: Reply with quote
clankity clank = bearings? Tie rod end?
eek eek = new bushings/ springs. if low miles could be settling in, or somethin didnt get lubed perhaps.
just some guesses from previous experience.
DankNesS
PostPosted: Mon Oct 30, 2006 11:10 am    Post subject: Reply with quote
hey thanks a bunch.. by bearings you mean wheel bearings? both front have been replaced if so. how would i go about testing the tie rod end? it seems i get movement that ought not be there when i pull on the bar in front of my steering stabilizer- i think it is called the stabilizer bar... it is completly locked into place on my ladies jeep but mine wiggles a bit...
thats wat i was hoping with the eek eek sound... i just lifted my jeep it has prolly under a 100 miles oin the new lift so it should be nothing to worry about ...
monkeyman3875
PostPosted: Mon Oct 30, 2006 12:57 pm    Post subject: Reply with quote
Not sure your clank/eek is related to your tie rod. Usually with a tie rod problem comes a death wobble. But, to test your tie rod, jack up the front end and wobble the weel side to side by grabbing at 9 and 3. If it wiggles, you probably need a new tie rod end. If that is inconclusive, jack up the entire front end and have someone turn the steering wheel back and forth while you watch the tie rod ends, and the drag-link, and pitman arm for movement. If there's play in any piece of the suspension it could contribute to your problem. If you see movement, but no breakage (since you just lifted) make sure all the bolts are tight. Generally, after you fix something, you should go back over it after 200-300 miles, and then again after a couple months to make sure it's solid.
Not sure that you'll find anything, but while you're under there, check your track bar as well.
What happened on mine was, I was having a serious death wobble when hitting off-set bumps. Found that the driver's tie rod end had broken and the bolt was floating freely in the socket. Had to chisel off the nut to get the end out of the knuckle.
Also, any other symptoms will help to diagnose problem.
-1997 Stock XJ
-4.0 L
-4-speed automatic
DankNesS
PostPosted: Wed Nov 01, 2006 1:57 pm    Post subject: Reply with quote
hey thanks a bunch!!!
IM not sure about the tie rod so im gonna do the test now. im fearly certain the track bar is cool cuz i got a new adjustable one and a better bracket for it so im fairy sure it coo. my drag link and pitman arm llok kinda hammered as well as my tie rod ends so i dunno.. any good places to get these parts that you know of?
DankNesS
PostPosted: Fri Nov 03, 2006 3:41 pm    Post subject: HELP IS APPRECIATED!!! Reply with quote
well damn tie rod actually seems fine... let me explain it better... real slow like after i just star my jeep and am leaving when i turn either way it pops and all the while it sounds like a freakn seal making love... eeewwuh wuwewewheheheh continuous..... ANY OTHER IDEAS??
chiphazard
PostPosted: Fri Nov 17, 2006 12:34 pm    Post subject: snap crackle pop Reply with quote
I had the same problem. It was the track bar. It is a good bet that the inner tie rod is gone too.
DankNesS
PostPosted: Fri Nov 17, 2006 2:26 pm    Post subject: Reply with quote
the track bar is bran spankn new from kevins offroad. adjustable and new braket. the tie rod is what im leaning towards is there anyway to test the tierod ends? befor just replacing them?
PostPosted: Fri Nov 17, 2006 6:34 pm    Post subject: Reply with quote
I would suggest having someone cycle the steering wheel right and left from full lock to full lock while you look at the steering components..
Crab the steering rod and wiggle it.. If its loose grease it ... If its still loose replace it..
Most parts on suspension can be tested by just wiggling them..
I would make very sure the track bar is tight .. and also check the control arms ..I used to get alot of crackling when I drove and it ended up being a bad control arm bushing on the drivers side upper..
Control arms should be very tight .. Hardly any motion at all ..
Good luck..
Carl
