amp ground/remote wire????
98CherokeeLTD
PostPosted: Sun Nov 05, 2006 9:00 pm    Post subject: amp ground/remote wire???? Reply with quote
98 Cherokee Limited....
First problem...2 questions...
I installed an Alpine H/U...had no problems. for the installation of sub/amp (Infinity Basslink), i ran the RCA cables and power cable already. my 2 questions are...
#1. Where would be the best place to connect the ground to in the trunk/cargo area or even under the back seat if needbe?
#2. I need a remote wire hooked to the amp also. Where is the best place to tap power from for that? Preferrably switched power under dash somewhere.
Second problem...1 question...
I am also installing a PA/Siren/Animal Sound Horn. I figured out what i am going to do for power so that the unit wont have to permanently mounted. I can unplug the power and wires to speaker and put the unit in the back seat if i want to.
soooo the question is.....
where would be the best(easiest) place to mount the speaker?
i kinda wanted to mount it somewhere behind the front bumper so it wouldnt get too hot from the engine, still be semi protected from rocks (rocks kickin up off the road and from rocks off roadin) and protected from directly being rained on, and also wanted it toward the front so that way it would be nice and LOUD.
Any help with any of the questions posted would be greatly appreciated!!
98CherokeeLTD
PostPosted: Mon Nov 06, 2006 1:15 pm    Post subject: Reply with quote
anyone with any help? please?
PostPosted: Mon Nov 06, 2006 2:39 pm    Post subject: Re: amp ground/remote wire???? Reply with quote
Anywhere you can get to the body and clean off the paint so you'll have a clean ground.
You would actually want to run this from your head unit. There is a remote turn on lead as part of the wiring harness coming out of the head unit. Usually, this is a blue wire. It's used to turn on amplifiers or power antennas. This will turn on the sub when the head unit turns on.
....wanted it toward the front so that way it would be nice and LOUD.
I think you should mount it on the inside right up by where your seat belt attaches on the B-pillar. It will be nice and loud there.
98CherokeeLTD
PostPosted: Mon Nov 06, 2006 5:04 pm    Post subject: Re: amp ground/remote wire???? Reply with quote
haha really funny.
i got the amp hookup done...everything works
used the remote turn on wire on the back of the H/U and where the back seats mount for the ground. I got these suggestions from someone else on a different jeep baord
