97 Grand Cherokee V-8 weird idle??????????
rtlofishing
PostPosted: Wed Nov 08, 2006 7:20 pm    Post subject: 97 Grand Cherokee V-8 weird idle?????????? Reply with quote
I have a weird idle situation o my V8..At idle it is 9.5 out of a 10 as far as being smooth..Problem is if your stopping or leaving a redlight right off idle but not really in the gas.. just off the brake,it seems to surge or skip until you get in the gas...I have cleaned the throttle body & IAC...Other than that it runs great.....Any ideas or thoughts??????????????????
PostPosted: Wed Nov 08, 2006 10:21 pm    Post subject: Reply with quote
Have you tried changing the TPS (throttle position sensor)
Did you use Throttle body cleaner to clean it ??
rtlofishing
PostPosted: Thu Nov 09, 2006 3:50 pm    Post subject: Reply with quote
It is a choice between the TPS and the IAC...Yes I used the throttle body cleaner...I have a friend that is going to give me a Chrysler Intake treatment system that will go half in the tank and the other half thru the intake...Which sensor has the most effect on idle,in gear,easing off the brake w/o touching the gas...???????????????????????????
chiphazard
PostPosted: Fri Nov 17, 2006 12:31 pm    Post subject: idle Reply with quote
my remedy after 5 weeks was to replace the IAC with a Mopar IAC. This did it for my 97' Jeep GC 4.0.
rtlofishing
PostPosted: Fri Nov 17, 2006 2:21 pm    Post subject: Reply with quote
Chip...Was yours idleing about the same way?..I have already done a tune up but to no luck......Was Mopar higher than the others or just better....
PostPosted: Fri Nov 24, 2006 5:02 pm    Post subject: Reply with quote
I replaced my IAC becuase when I would let off the gas the idle would drop down, and if I was going slow enough, stall. Then sometimes if I started it up after not letting it sit a while the rpms would drop and stall or they would jump up and down for a while untill they evened out at about 800ish.
Anyway that is a discription of my problem and a new IAC from autozone fixed it right up.
