87' cherokee water leaking in
jeepunit
PostPosted: Wed Nov 15, 2006 12:44 pm    Post subject: 87' cherokee water leaking in Reply with quote
hi this is my first post, I have a problem with water leaking onto my passenger side floor, i can tell its dripping from under the glovebox, somewhere possibly from the heater core Confused i've heared of drainage holes that get clogged with dead leave's, pine needles etc. but i cant find out how to get to them HELP MEEE.
-thanks
xj88
PostPosted: Wed Nov 15, 2006 10:21 pm    Post subject: Reply with quote
i have the same problem , but my leaking is the rear, near the hatch, but the lift gate doesnt leak. it might be rust from underneath. if you find the drain plug let me know.
JeepinNH
PostPosted: Fri Nov 17, 2006 11:08 am    Post subject: leaks Reply with quote
Both leaks are typical.
The rear hatch sometimes leaks around the window after the seals dry out and shrink. Also have seen them leak around the door seal.
I've had leaks under the dash coming from the firewall and had 1 leak following the antenna wire. The wire goes through the right side body with a plastic/rubber piece to stop water from coming in. Someone had replaced the antenna on mine and neglected to seal it back up. I had a GC that leaked from a firewall seam, I had to remove the piece under the wiper arms and fill the seam with silicone. I cleaned all the pine needle debris out of the area at the same time.
Both issues I found by having someone run water from a hose all over the suspect area while I was inside with a flashlight looking for drips.
Mike
Present: 99 Cherokee
jeepunit
PostPosted: Fri Nov 17, 2006 5:24 pm    Post subject: Reply with quote
thanks man your a life saver! er... jeep saver?
