Engine Cooling Question - New solution?
micklouie
PostPosted: Sun Nov 19, 2006 6:28 pm    Post subject: Engine Cooling Question - New solution? Reply with quote
I have a 1996 Jeep Cherokee Classic. 4.0 High Output.
I have a question about the engine cooling issues.
I seem to have a problem with keeping the engine running cooler.
I haul kayaks on the top, which put a load on my Jeep.
It creates a lot of wind resistance and tends to bring temperatures up.
I have seen people put grille on their hoods.
I was checking out my Jeep and thought of another solution.
I wanted to see if you thought of this technique.
I notice the cowl area of my Jeep where the windshield wiper motor mounts.
This area is wide open. The cowl vent area where the wind shield motor mounts has holes in it. I thought of drilling holes in the back area of the engine bay. I could use a hole saw to make the opening. This would allow the heat to escape out of the back of the engine compartment.
Is this area used for a special purpose for heating and cooling?
Would appreciate any advice on this topic.
Mike
Asheville, NC
soberidiot22
PostPosted: Sun Nov 19, 2006 7:42 pm    Post subject: Reply with quote
i have a 1996 XJ I6 High output too and about 4000 miles ago im at 165K i had a problem with my engine running too hot. i decided to replace the thermometer and it worked for me. my engine was running hot wherever i went and was especially bad in the mud
hope this helps
kyle
Renegadestang
PostPosted: Mon Nov 20, 2006 6:25 am    Post subject: Reply with quote
Did you mean the "thermostat"? rofl
soberidiot22
PostPosted: Mon Nov 20, 2006 6:28 am    Post subject: Reply with quote
yea thats what i meant
where did i get thermometer????????
since when do cars have thermometers lol
PostPosted: Mon Nov 20, 2006 9:32 pm    Post subject: Reply with quote
What temoerature is it running at? If it's around 210, that's where the 4.0 runs. If it's pushing 220, you can try upgrading to a 3 row radiator and add a tranny cooler and hi flow thermostat housing. Replacing the viscous fan clutch will help as well. Those mods will drop the running temperature by 10-20 degrees.
http://jeephorizons.com/tech/xj_cooling.html
Renegadestang
PostPosted: Mon Nov 20, 2006 9:46 pm    Post subject: Reply with quote
Micklouie, I just took notice that you live in Asheville. I'm just down the road from ya. Hit me up anytime you wanna wrench or ride, I'm down for it! Mr. Green
