Damaged teeth on Dana35
dubbleJ's
PostPosted: Sun Dec 03, 2006 6:04 pm    Post subject: Damaged teeth on Dana35 Reply with quote
Pulled the rear diff cover on my 91 XJ tonight to find this:
Anyone know how serious this damage looks and how hard of a fix it is?
PostPosted: Mon Dec 04, 2006 2:11 pm    Post subject: Reply with quote
That's actually a pretty easy repair.
Get yourself new spider and side gears.
Remove the brakes, remove the center pin, remove the c-clips, pull the shafts, remove/replace the spider and side gears, then reverse the general procedure above.
dubbleJ's
PostPosted: Mon Dec 04, 2006 4:03 pm    Post subject: Reply with quote
Good to hear its not an overly hard job...even though that list of things to do sounds..fun. Smile
Is there any write ups with pics etc on how to replace spider and side gears?
How much $$ are these gears going to run me?
330T
PostPosted: Tue Dec 05, 2006 2:00 pm    Post subject: Reply with quote
make sure you find the rock, chunck of steel that did the damage and get it out...
kizer
The Link Meister
The Link Meister
PostPosted: Tue Dec 05, 2006 3:30 pm    Post subject: Reply with quote
Here you go. This is from my Super35. You will have to remove a hex bolt opposed to an hex key like I did. This is from a disc brake swap, but it should give you a pretty good idea on how easy it is.
http://www.links4jeeps.com/writeups/d35discconversion/
Links4Jeeps.com
1600+ Write-ups, and more
My Writeups | My Heap
PostPosted: Tue Dec 05, 2006 3:32 pm    Post subject: Reply with quote
They're pretty cheap and if you throw up a WTB post on a busier forum, you could get them pretty easily.
Writeup??? Check out www.stu-offroad.com
http://www.stu-offroad.com/axle/d35/d35-1.htm
dubbleJ's
PostPosted: Wed Dec 06, 2006 8:37 pm    Post subject: Reply with quote
Thanks for the links guys. It does look fairly simple to pull the axles out, but after I do that how do I actually get the gears out of the diff and place the new ones in?
PostPosted: Thu Dec 07, 2006 2:35 pm    Post subject: Reply with quote
They will rotate. Just spin them until they are in the opening and remove them.
kizer
The Link Meister
The Link Meister
PostPosted: Thu Dec 07, 2006 3:48 pm    Post subject: Reply with quote
Trust me once you pull that pinion mate shaft and that chrome looking H shapped thing they will practically fall out. Very Happy
Links4Jeeps.com
dubbleJ's
PostPosted: Fri Dec 08, 2006 5:30 pm    Post subject: Reply with quote
Aha ok sounds fairly simple. Is the installation of the gears as simple as taking them out?
Also I was thinking of just hitting a junk yard and trying to grab new gears out of an XJ, would be much cheaper and dont know if its worth putting a locker in my D35...?
