auction coming up
rhgreen
PostPosted: Thu Dec 07, 2006 7:13 pm    Post subject: auction coming up Reply with quote
*Back in the white room, takes the time to look about She is sitting on a hospital type bed, stark and white, there are number benches, and cabinets around the walls In the cabinets and on the ben
components with regard to their location that a naive T cell can proliferate and delivery of SIVmac239 DNA complexed
ED, You should go to this link and read the article and comments by others who bought either one or both sets. Opinions vary among fans, and of course it depends on your system too. And you are l
I would definately do as said above if u want more work by the guy tip good and establish a good relationship out of the gate and the artist will take care of you in the future then when u are gettin
88WOWJ
PostPosted: Sat Dec 09, 2006 8:16 am    Post subject: Door ajar switch Reply with quote
One of the five doors has got a bad switch.
If you have a multimeter OHM is out.
Or disconnect each switch but be careful the switch wires are live all the time and dont let them fall inside the frame assembly.
as for your idle problem the dead battery caused your idle problem the computer was relearning.
1991 Cherokee Limited
rhgreen
PostPosted: Sat Dec 16, 2006 5:03 am    Post subject: Reply with quote
Just a follow up. The 4 door switches seemed to be working fine... the lift gate light has not worked since I aquired the xj in April, so I pulled the panel off to discover the liftgate light switch had melted. Disconnected the switch and it seems the problem has gone away. It is a Jeep so I will probably live with no liftgate ajar indicator or rear dome light operation at the rear gate.
