4WD Not Working
jeepromper
PostPosted: Wed Dec 06, 2006 4:53 pm    Post subject: 4WD Not Working Reply with quote
I have a 86 Cherokee laredo 2.8 V6 and my 4WD is not working.
Any ideas?
935speedxj
PostPosted: Wed Dec 06, 2006 10:57 pm    Post subject: Reply with quote
well hi.... does the 4wd lever move? if so check an see if u have a vacume silanoide sometimes they get a vacume leak or just freeze up... if so go to a junk yard a pull one from there
93 cherokee 9 inch lift 6.5inch leafs 1.5 inch shackles 8.5 inch coils an lca's ..,jks disco's,front an rear steel tube bumpers ,an roof rack that i welded up an a bunch of metal that i cut off.... not to mention my wanna be wrangler doors ....
JeepinNH
PostPosted: Thu Dec 07, 2006 6:33 am    Post subject: 4x4 Reply with quote
With the lever in 2 wheel drive, reach under and see if the front drive shaft is spins, it should. Pull the lever to 4H, it should not spin now. If this checks ok then the front axle vacuum disconnect most likely is your issue. Like the previous post said, a vacuum leak will stop it from working or it could be stuck from non use.
Mike
Present: 99 Cherokee
2bucks
PostPosted: Fri Dec 08, 2006 2:19 am    Post subject: Reply with quote
It could also be the front axle shift fork is broken. Those type of axles were not made to shift on the "FLY" . Shifting it into 4WD any faster then 2 mph will break that fork.
jeepromper
PostPosted: Sun Dec 24, 2006 8:39 pm    Post subject: Thanks Reply with quote
Thanks you guys, It was the 4WD actuator. I replaced it and Viola it works.
Very Happy
Thanks for the input.
Jeepromper
