87 YJ electrical Problems
boog44
PostPosted: Sun Dec 17, 2006 4:13 pm    Post subject: 87 YJ electrical Problems Reply with quote
Hi all.....I am new here....just bought an 87 YJ have been working on it for about a month.....got it running pretty good. Now I'm having little Gremlins driving me nuts!! Evil or Very Mad When I turn on the headlights the engine runs like CRAP!!!!! I have checked the various grounds and cleaned the plugs and prongs.....Now what?????
Tardis
PostPosted: Wed Dec 20, 2006 2:46 pm    Post subject: Reply with quote
Check the charging system, altenator, battery, wiring, check the starter for a dead short, etc. A crappy diode in the altenator, bad voltage regulator will make the Jeep run bogus under a load.
98' TJ, 99' XJ
DozerDan
What the deuce?
What the deuce?
PostPosted: Wed Dec 20, 2006 10:05 pm    Post subject: Re: 87 YJ electrical Problems Reply with quote
Dont drive at night...
check the frame to block ground ?
check the headlight grounds?
check the bat to starter?
If you have then I would try this.... at your own risk.
Pull the switch out of the dash and jump the connections you need for lights. It is possible you have a bad switch, they can do WEIRD things.
Also does it vary if you have the headlights on high or low beam?
Worst case, pull the alt off and bring it to auto zone/pepboys ect and ask them to test it.
