Serpentine Belt
soberidiot22
PostPosted: Thu Jan 11, 2007 6:19 am    Post subject: Serpentine Belt Reply with quote
Does anybody know why my serpentine belt would be making a squeeling noise. after it started doing it i replaced the belt and that didnt work so then i tried some belt dressing and no luck. it seems to only do it when its wet out but it has happened while its dry out.
well now that i wrote this maybe its not even the belt maybe i just need some WD-40 on the idler pully. or any pully for that matter.
any ideas would be apprieciated
dancerman
PostPosted: Thu Jan 11, 2007 8:09 am    Post subject: Reply with quote
If you search the forums here... you will likely find other discussions of this problem. I am 99% sure that you just need to tighten it more. I tightened mine a little each day until no more squeeling.
TexAgs08
PostPosted: Thu Jan 11, 2007 11:00 am    Post subject: Reply with quote
Mine did the same thing. I changed it and it was still squeeling. All i did was dress it REAL good everyday for about a week and it finaly went away.
PostPosted: Thu Jan 11, 2007 2:39 pm    Post subject: Reply with quote
Tighten it a little bit.
c130herc
PostPosted: Thu Jan 11, 2007 9:29 pm    Post subject: Reply with quote
Could be the idler pully bearing. They are easy to replace. There about $30 for the whole pully but you can get the bearing and just use a vice.
The bearing itself is about $4 at the auto parts store.
Part# 203FF
majikxms
PostPosted: Fri Jan 12, 2007 6:01 am    Post subject: Reply with quote
Try tightening it before you start buying parts...yes, it could the the bearing, but if it just needs tightened...
