98 cherokee sport turn signal & hazard lights stopped wo
beaglebus
PostPosted: Sun Jan 14, 2007 6:29 pm    Post subject: 98 cherokee sport turn signal & hazard lights stopped wo Reply with quote
Hi there. The Turn signals and Hazard flasher have ceased working on my
98 cherokee sport for no apparent reason. Mine is the 2.5 turbo deisel version but I am assuming this portion of the Electrics is common ??.
My manual doesn't include any electrics . Where do I find the turn signal flasher relay please and if anyone has experience or suggestions regarding the problem I'd apreciate your help.
Thanks.
JeepinNH
PostPosted: Mon Jan 15, 2007 7:55 am    Post subject: flasher Reply with quote
According to my manual the same flasher is used for both turn signals and hazards on 97 and newer Cherokees. You remove the knee blocker under the steering wheel to get access to it. It looks to be straight up from the OBD connector. Make sure you check the fuses too, there's a fuse box by the passenger feet behind a small door, it may be in there.
Mike
Present: 99 Cherokee
beaglebus
PostPosted: Mon Jan 15, 2007 11:45 am    Post subject: Reply with quote
Thanks Mike. I'd checked the fuses by the accelarator and removed the Knee panel etc but obviously haven't looked hard enough. I'll have a proper look tonight or perhaps get my wife to look . She reckons Men can only find something if its right on the end of their nose....
Cheers.
