inertia switch
PostPosted: Tue Jan 30, 2007 8:54 pm    Post subject: inertia switch Reply with quote
any one know were the inertia switch is located in a 91 cherokee 4 door limited .
it had an accident , and i can't find it in the manual , im guessing around the passanger side kick pannel ?
does it have one ? i havent tried starting it yet due to the fact the ac unit is still inside of the battery , but will probobly have it ready tomorow Smile
88WOWJ
PostPosted: Wed Jan 31, 2007 6:11 pm    Post subject: inertia switch Reply with quote
I have a 1991 Cherokee Limited.
You got one on me.
Dont know what your talking about??
PostPosted: Wed Jan 31, 2007 6:46 pm    Post subject: Reply with quote
when your vehicle gets in an accident it has a switch that will shut off the fuel pump so that it doesn't pump fuel all over the place light fire and burn to the ground .
also works as a role over switch but should go off when it gets in a accident and looks like this
PostPosted: Thu Feb 01, 2007 5:58 pm    Post subject: Reply with quote
im starting to think there isnt a switch cuz i got the fuel pump to work but it wont turn over so maybe i blew the starter fuse
