ELECTRICAL CONNECTOR TERMINAL PROBLEM.. PLEASE HELP!!!
DJ BABY FINGAZZ
PostPosted: Mon Jan 29, 2007 4:06 pm    Post subject: ELECTRICAL CONNECTOR TERMINAL PROBLEM.. PLEASE HELP!!! Reply with quote
i have 1994 jeep grand cherokee ltd. i replaced the coolent temp sensor and upon doing so the electrical conector terminal was dry rotted and broke. is there any way of buying a kit to make new ones for problems like this one? what can i do or go to get a new replacement. i checked local junk yards but no luck. no one seems to know where to get one. a friend said there should be a kit i can get to make one is there such thing? if anyone knows where please help me out. i hope it's called a ELECTRICAL CONNECTOR TERMINAL if not what is it called. thanks guys!!
DankNesS
PostPosted: Mon Jan 29, 2007 5:27 pm    Post subject: Reply with quote
that definately happens a lot.. i have broke a few tabs.. all i use to fix em is a zip tie to keep them connected.. i would say rig it best you can.. unless you find a the same part at a junk yard or a build it yourself kit.. those of course are better
DJ BABY FINGAZZ
PostPosted: Mon Jan 29, 2007 5:38 pm    Post subject: Reply with quote
where can i get the kit from? and what is it called? thanks...
DankNesS
PostPosted: Mon Jan 29, 2007 8:27 pm    Post subject: Reply with quote
no clue sorry.. have you looked on google or ebay?
DJ BABY FINGAZZ
PostPosted: Mon Jan 29, 2007 8:47 pm    Post subject: Reply with quote
YEAH AND NO LUCK. I LOOKED ALL OVER AND STIIL CANT FIND SOMETHING.
PostPosted: Mon Jan 29, 2007 8:50 pm    Post subject: Reply with quote
Please don't type in all caps.
PostPosted: Tue Jan 30, 2007 10:43 pm    Post subject: Reply with quote
Hit the bone yard again..
IF you have the 5.2 check dodge trucks.. They will have the same sensors..
IF you have a 4.0 check Cherokees and TJ's ..
If you cant find it on any of those.. Is it a single or double terminal plug??
You can make one from a couple of bullet connectors sqeezed down small enough to hod the pins on the sensor...
Good luck..
DJ BABY FINGAZZ
PostPosted: Wed Jan 31, 2007 6:29 am    Post subject: Reply with quote
Good luck..
it's a double on a 5.2 v8. what year truck would i have to look for and size engine? thanks
PostPosted: Wed Jan 31, 2007 7:42 pm    Post subject: Reply with quote
5.2 in trucks has been pretty much the same from 88 or so til about 2000 .. You shouldnt have a problem finding a dakota or Ram with a V8 that you can get it off of..
Good luck..
DJ BABY FINGAZZ
PostPosted: Thu Feb 01, 2007 9:22 am    Post subject: Reply with quote
thanks ill see if i can find one. i wish there was a kit you can buy or something.
