factory alarm
PostPosted: Sat Feb 03, 2007 9:56 pm    Post subject: factory alarm Reply with quote
i have a 91 xj limited with a factory alarm with no remote for it . the problem is i can't get the thing to start because the alarm just goes off constantly when i hook the battery up . so i unhooked the alarm module . what else do i have to do to get around this alarm does anyone know or know of some were that can tell me ? thank you
the fuel pump goes on but the thing just wont turn over .
88WOWJ
PostPosted: Tue Feb 06, 2007 7:17 pm    Post subject: Factory Alarm Reply with quote
I have 91 XJ with alarm.
Rollup and lock all doors. To include the gate.
Disable the horn if need be.
Make sure the battery is full charged.
A low or weak battery will not let the alarm reset.
The park lights should flash.
This should take about 5 minutes for the alarm to reset.
When the lights stop flashing the alarm is reset.
Engine should start
By you disconnecting the module one under the dash.
The engine disable is in the ECU so it it may not start.
Toe reset the module memory disconnect the battery negative cable.
The reciever for the alarm is in the over head console.
The 91 Transmitter is discontinued.
Locate a 1992- 1994 the transmitter is avaiable from jeep
1991 Cherokee Limited
PostPosted: Wed Feb 07, 2007 7:27 pm    Post subject: Reply with quote
thank you . im guessing the transmitter from a 92-94 will work with that receiver ? i got it to start with a starter jumper/button and it ran fine , so if i lock all doors and have windows rolled up leave it for five minutes and then come unlock the door it will allow me to start it up ? thats great news , any idea what a transmitter is worth 50$ ? how do i reprogram the transmitter?
thank you again
88WOWJ
PostPosted: Wed Feb 07, 2007 8:07 pm    Post subject: Factory Alarm Reply with quote
I was told it is self programing?? Dont honestly know.
I have never purchased a new transmitter.
Try this web site for aftermarket transmitters.
http://www.thejeep.com/pilandcode.html
PostPosted: Wed Feb 07, 2007 9:34 pm    Post subject: Reply with quote
ok thank you , i will probably talk to jeep about it . or search around on the net .
