New Wrangler
soberidiot22
PostPosted: Tue Feb 20, 2007 12:40 pm    Post subject: New Wrangler Reply with quote
Hey everybody,
I am a current XJ owner and i found a wrangler in good body condition. this jeep hasnt been ran for 2 years so im worried about getting it started. im planning on temporarly getting new gas, run iso heet, and sea foam through it. maybe ether to get it running. if i get it running i will do an oil change.
does anyone else have any other ideas to make it easier.
majikxms
PostPosted: Tue Feb 20, 2007 1:11 pm    Post subject: Reply with quote
Might do an oil, oil and air filter and tranny oil change and maybe spark plugs and wires too before you try to start it. Just a suggestion, but if it's been sitting for 2 years that stuff may need to be changed. What year is it, maybe change the cap and rotor if it has one?
soberidiot22
PostPosted: Wed Feb 21, 2007 7:56 am    Post subject: new wrangler Reply with quote
its a 94
do you recomend doing the wires and spark plugs, cap and rotor before i try to start it?
PostPosted: Wed Feb 21, 2007 8:47 am    Post subject: Reply with quote
If you're just trying to get it started to check it out or get it home, then fresh gas and a can of ether should do the job. You may need a battery too! If it's already yours then do plugs, wires ,cap & rotor, air cleaner, fuel filter, pcv, and oil change. Clean up the throttle boby inside and out. Change the tranny, diffs and t-case fluids. Flush and fill the cooling system. This it what I would do because who knows when it was last done. Also I would do it just for the fun, I love working on a new to me vehicle. It is also a good way to get to know you're new rig!!!
majikxms
PostPosted: Thu Feb 22, 2007 6:45 am    Post subject: Reply with quote
Yeah, make it your own rofl
