squeeeeeeky sterring wheel!
Austentatious07
PostPosted: Wed Feb 28, 2007 6:25 pm    Post subject: squeeeeeeky sterring wheel! Reply with quote
I was wondering if anyone could help me out here. I live in oregon, and durring the winter, it gets really cold durring the night.(duh) anyways in the morning when i go get in my car and go, the sterring wheel squeeks like crazy when im turning. what should i do about this? new sterring wheel? losen something up? thanks for the help
PostPosted: Wed Feb 28, 2007 7:34 pm    Post subject: Reply with quote
do you mean the actual steering wheel itself is squeeking ? like the frame of it and ring ? or there is a squeeking noise when you turn with your vehicle cold?
Austentatious07
PostPosted: Wed Feb 28, 2007 9:53 pm    Post subject: Reply with quote
its the steering wheel, not the engine or anything. it just squeeks like the steering wheel is rubbing or something
PostPosted: Thu Mar 01, 2007 2:05 am    Post subject: Reply with quote
There was a TSB for the TJ's for a similar noise when it gets cold - might be worth a try on yours.
http://jeephorizons.com/phpbb/viewtopic.php?t=404
JeepinNH
PostPosted: Thu Mar 01, 2007 8:32 am    Post subject: squeeks Reply with quote
Mine squeeks when cold too. So far I've just ignored it. Mine sounds like it's the plastic rubbing. You can try swabbing some silicone lube in between the plastic that covers the back of the wheel and the cover that goes over the steering pod.
Mike
Present: 99 Cherokee
TheBrat97
PostPosted: Thu Mar 01, 2007 9:34 am    Post subject: Reply with quote
That's what I did...get some silicone spray it works just as well
