Drivetrain Identification ZJ 93'
cooperZJ
PostPosted: Sat Mar 03, 2007 6:20 pm    Post subject: Drivetrain Identification ZJ 93' Reply with quote
I'm looking to get a locker, but am not sure what drivetrain I have.
I've seen some sites that claim it's a D35 and others say its a 44.
Also, how many splines? and what is the hub diameter?
/thanks
PostPosted: Tue Mar 06, 2007 8:19 pm    Post subject: Reply with quote
PICS OF A D35 AND A CHRYSLER 8.25 REAR AXLES (8.25 is on the left, D35 is on the right)
http://www.rocklizardfabrications.com/C_8.25_Picture.jpg
the Chrysler is easy to spot because of the flat bottom
if it is nether of these then it should be the 44 . there should also be a tag on the axle or it might say on the diff cover
5.9 andy
PostPosted: Tue Mar 06, 2007 9:17 pm    Post subject: Reply with quote
if it is the D44 look out because it will most likely be a D44A which means that the differential housing is made of alumanum instead of steel. it should be of if u wheel it mildly but if u do hardcore stuff LOOK OUT!
if it dose turn out being the D44A do some research in the grand cherokee section, im shure there is some good info on it.
PostPosted: Tue Mar 06, 2007 10:49 pm    Post subject: Reply with quote
use a magnet if it sticks to the cover its a d35, if it doesnt then its the 44a
cooperZJ
PostPosted: Wed Mar 07, 2007 8:14 am    Post subject: thnks Reply with quote
Yes,
I checked and I do have a D35. Matches the pic and it is steel.
Thanks
5.9 andy
PostPosted: Wed Mar 07, 2007 5:27 pm    Post subject: Reply with quote
how much money do u have to spend?
if u got some extra i would say get rid of the D35 and get a ford 8.8 out of a 2003 explorer if u can, my friend just droped one into his wrangler and that thing has one hell of a limited slip that u can beef up or get lockers for em 2.
cooperZJ
PostPosted: Thu Mar 08, 2007 5:54 am    Post subject: difficulty? Reply with quote
Switching a rear dif seems pretty challenging. I would have to weld mounts for all of the hardware that attaches to it. I have a GC, how hard is this to do? How much did your friend pay to do this? Parts/ labor?
PostPosted: Thu Mar 08, 2007 11:28 am    Post subject: Reply with quote
its a fairly difficult swap, you would need welding experience, after all the welding is finished you will need wheel spacers
so it would cost a pretty penny if you paid for it to be done
5.9 andy
PostPosted: Thu Mar 08, 2007 4:27 pm    Post subject: Reply with quote
for the axle it self he paid $500, for instal i dont remember. like i said, its if u got a prety good amout of money 2 spare.
